Most WHP on Pump Gas 93/94 Octane
Originally Posted by KOEvo
^ You should remove your middle paragraph there about why you dont like racegas/injection because it is just personal opinion. I see what you're saying, but this thread is going to turn into a why racegas/injection systems aren't bad for your car.
And this is to good of a thread to ruin.
For a GT35R yes, for a T4 GT35R no. I bet your turbo shine's on race gas, but thats not what this thread is about, but lets see......
Scorke
p.s.- tiny cams should help tq but help topend, I dunno what explains it, if you have the sheet post it up, I bet it is just a by product of the laggy hotside.
Scorke
My Evo 6 put down 422 WHP AWD at 22 psi on a Dynojet running a 2.3 stroker engine with a TRust T67-8cm turbo kit and HKS 280 cams hitting full boost of 22 psi at 4100 rpm, am targeting 450 WHP at the same boost on my new GT35R setup
On the very same day, a brand new Evo IX running a Kelford 272 exhaust cam, Autronic SM4 ecu, 700 cc injectors, stock fuel pump putting out 365 WHP on the same Dynojet at 23 psi on a stock TME turbo.
All of the above on 93/94 octane pump gas only.
Originally Posted by scorke
Carlos you seem nice, and well intentioned but I am going to have to ask, did you read the first post?
Scorke
Scorke
It is all good now and again sorry for the inconvinience and thanks for being nice when responding me.
I also sent you privately an apology but your PM was full
Carlos
Hehe np man, just trying to keep this thread on track!!!!!!!!!! Bump for more pump gas monstars, I'll update again around noon, and I will do some searching on my own for some impressive numbers with the smaller turbos.
Scorke
Scorke
Originally Posted by trevor
I belive I dyno'd my '04 on the same Dynapack as jj_008 when it was bone stock, and it came out to 225 AWHP, which I thought was pretty accurate. If Dynapacks read high, I don't think they're THAT high. Actually I think they are relatively accurate, but it may be worth comparing #s from a dynapack to a dynojet and so forth.
