Is my BOV in backwards; is it a big deal?
Originally Posted by deadbeatrec
haha looks to me its not even hooked up. i sure hoop u reattached the hose going into the ic pipe.
Originally Posted by hokiruu
Interesting. My BOV was on backwards when I bought mine too, except I am the fourth or fifth owner! (Dunno what it is about Evos getting passed around like that, but I'm the first to DD it.) I do know that it was always taken to non-performance, general-maint. shops to have any work done, and I know that the BOV was reinstalled. I ranted and bashed the shops for their ignorance when I saw the backwards recirc. valve, but now I see that in all probability they just didn't know any better and were putting it back on the way it came! Which is why I do all my own work around here...
I'm actually surprised D.B. didn't see it when tapping my boost line to their dyno computer. Wasn't exactly looking for/ at it, though.
Originally Posted by Mike@Forge
You should switch it around.
It won't operate 100% properly installed in that configuration.
It builds boost faster, harder, and holds stronger than any other setup I've tried - it's just so dam noisy and, well.... a little strange
I had to install my Forge DV backwards because the vac line was too short. Works fine though. Although now I'm not sure if I'm just getting flutter on occasion, or compressor surge. It only happens at high speeds in 5th when I'm "lazily" excelerating like someone else said. Modulating the throttle if you will.
ok, im confused...how in the hell are these backwards bov even being recirc'd? the tube from the bov to the intake pipe isnt big enough to stretch around and fit right...or does it? idont remember the stock one lol
When my engine is semi-cold.....and i give it boost to about 15psi....then go back to "easy driving" i have fluttering sound..... is it b/c the engine is not up to proper temps yet?..... and sometimes it sounds like the spring is stuck and then i give it boost and its fine? confusing sometimes.
