500whp stock block club
Old Jan 19, 2007 | 09:37 AM
  #121
G20's Avatar
G20
Originally Posted by SilverNine
ok 500whp.... But for how long?!?.....
At least more than 2 years since I've been running my 03 evo with 530whp for more than 2 years. Yes! I went to drag strips almost monthly and running around on SoCal freeway every weekend. Just make sure you get a good tune (mine is Tuning Tech) and monitor the car's condition (i'm using Zeitronix).
Old Jan 19, 2007 | 10:36 AM
  #122
High_PSI's Avatar
The stock bottom end is VERY stout. Remember that a vendors advice or building a block or stroking it no matter how nobel is still based off of making an income. The OEM block is also built to very tight tolerances with precise industrial machinery.
I seriously doubt that any aftermarket block (Baring the stupid expensive Cosworth/JUN blocks) would meet the tolerances of an OEM block and be more likely to spin a bearing or break apart. I simple search shows more aftermarket blocks blowing up vs OEM but then again they always try to run more WHP.
IDK, the OEM block is amazing, that's for sure.
Old Jan 19, 2007 | 11:17 AM
  #123
ctracer911's Avatar
Those are some nice numbers for a stock block. I cant wait to see some 700whp freaks. I think a small shot of nitrous might help out a little
Old Jan 19, 2007 | 12:32 PM
  #124
High_PSI's Avatar
700WHP would not work on a stock block, If you want confetti go for that I guess...
Old Mar 28, 2007 | 02:26 PM
  #125
TFJasonO's Avatar
Thanks for adding our Dyno chart to the list! We hope to keep pushing the envelope and disclose any information good or bad that we might come across!
Old Mar 28, 2007 | 02:29 PM
  #126
Paul Nelson's Avatar
LOl TF did a 150shot to get that # what do you consider small?
Old Mar 28, 2007 | 07:02 PM
  #127
yesevo's Avatar
nobody blow up enigne yet?
Old Mar 28, 2007 | 07:22 PM
  #128
kmcconn9's Avatar
I hopefully should have something to contribute to this list come April 28th....
Old Mar 28, 2007 | 09:40 PM
  #129
TFJasonO's Avatar
I look forward to seeing the list grow!!
Old Apr 5, 2007 | 02:56 PM
  #130
kmcconn9's Avatar
looks like the stock block and flash record is 504.29.....I might have something to say about that come April 28th...
Old Apr 5, 2007 | 03:10 PM
  #131
Sean@Iveytune's Avatar
Wrong, I have done several flashes over 520hp both evo8 and 9 on stock block, but what is a record anyway.
Sean
Old Apr 5, 2007 | 03:21 PM
  #132
High_PSI's Avatar
God damn Sean how does that Supra's Auto Box hold all that power? It's nuts!
Old Apr 5, 2007 | 04:15 PM
  #133
I am shocked myself drives daily no issues, Boostlogic builds it.
Sean
Old Apr 5, 2007 | 06:08 PM
  #134
ray3328's Avatar
I made 515hp and 423tq on 100oct at 32 psi thanks to Sean. I'm sure he could have gotten even better numbers if I ran some higher octane but I don't want to use unleaded. I do admit that I normaly run 28psi that comes out to 480-490hp, that's more than enough power on the street. Not to mention the car runs great, no problems. Sean is the man
Old Apr 5, 2007 | 06:51 PM
  #135
scoob4fun's Avatar
Any of you guys using EMS for a IX I need your rear O2 sensor like no other. PM me if you have one, ill buy it!!
