ACT clutch & gear lock in
Old Aug 17, 2006 | 11:01 AM
big_huff's Avatar
i have had my act clutch in for a about a month now so i broke it in properly. so this is my problem when im wot my tranny likes to stick in the gear but it only happens after 6,000 rpm i think i might be because i need more tranny fluid but im not sure so if anyone has any ideas on why my car is doing this i would greatly appreciate it thanks.
Old Aug 17, 2006 | 11:16 AM
Smike's Avatar
Here...for lock-in -- check fluid level and for burning (smell and color), if the fluid is dark or smells burnt then you could be have a toasted tranny.
Or your clutch slave cyl. is going. This causes poor fluid pressure, and will not allow changing of gears.
For adjusting to go:
http://evomoto.com/tech_info.php?tec...68805bcc218503
Old Aug 17, 2006 | 12:28 PM
kjewer1's Avatar
I think what he is describing might be different than the usual gear lock out. Nothing in that link talks about what the original poster is asking about.
Mine will also stick in gear at high rpm, only in first, and only if I lift. When I no lift shift at the track it releases the gear just fine. I'm not sure what is causing this.
Old Aug 17, 2006 | 03:16 PM
big_huff's Avatar
appreciate your comment anybody else know what is going on?
Old Aug 17, 2006 | 03:22 PM
jmartinez1170's Avatar
I notice that when im at wot and shift from 3rd to 4th it doesnt want to go in i have to shift at like 7000rpm so it would go in and i have to force it in.
Old Aug 17, 2006 | 03:25 PM
big_huff's Avatar
i sometimes have a problem with 2nd to 3rd but im talking about being in 3rd and getting on it and going past 6,000 rpm and it gets stuck in 3rd and i have to wait for the rpms to drop before it will let go.
Old Aug 17, 2006 | 03:42 PM
AfireINSIDE's Avatar
I hear about these problems..... guess im lucky 2k and no issuses I love my ACT
Old Aug 18, 2006 | 12:02 PM
big_huff's Avatar
bump
Old Aug 18, 2006 | 04:32 PM
vwjeff's Avatar
I think this is a problem with ACT clutchs. Get rid of it and get another clutch.
Warrtalon had a huge write up on this, do a search there were like 15+ pages on it, and the bottom line was that ACT or any type of oragantic clutch sucks... My stock clutch gets 7k lock out, when it gets hot.
Ralli_Red
22
Oct 16, 2015 05:38 AM
aldoevo
Jun 24, 2013 11:04 PM
dryad001
62
Mar 2, 2007 04:45 PM
willie torres
13
Sep 7, 2006 02:22 AM
JVELA
Oct 17, 2005 04:41 PM
