what exhaust system gets the most WHP gains?
Old Apr 8, 2007 | 11:28 PM
  #76
OmgGG's Avatar
yes id like to know if they do make more gains than ams
Old Apr 12, 2007 | 02:36 PM
  #77
90GSX-03EVO's Avatar
Originally Posted by h.funk
How do you lose torque when you gain hp?
That isn't really the case. Turbo cars are not like N/A cars in which more backpressure will create low-end torque and free flowing exhaust will cause nice peak horsepower numbers but kill your peak torque.
For turbo cars, it's more like you break over a threshold in the level of restriction where you have not enough restriction and the turbo's output pressure will creep up and down as it fills / tries to fill the void. You want some restriction in your exhaust, but the main need is at the turbine outlet only. With no restriction at all, losses are made because of boundary layer separation cause by a transition in pipe diameter (hotside outlet to O2 housing) at the point where turbulence is the most affected.
In other words, if you dump straight out of your hotside into open space, it will cause spikes and boost creep. If you step down your exhaust into an O2 housing and then into some form of a downpipe, it will "smooth out" the exhaust and cause it to actually flow more efficiently. Think of a venturi tube.
Super large exhaust pipes are nothing more than overkills and usually just cause clearance issues or noise polution tickets.
If you're really looking for the best flowing exhaust, get a 3 inch with an external wastgate that dumps to atmosphere.
Old Apr 12, 2007 | 02:37 PM
  #78
BOOSTED04's Avatar
Hpf!!
GavDarcy
Feb 20, 2010 02:00 PM
LoveBoost
29
Jan 30, 2008 10:19 AM
boostin@27
Jun 11, 2007 08:58 AM
rogerbslee
May 5, 2005 07:31 PM
1QWKEVO
34
Aug 11, 2003 07:40 AM
