fuel pump stock or not?
Old Nov 17, 2006 | 08:47 PM
redevo8u's Avatar
i purchased a used evo that has been modded in the past and im not sure how for they went. how can i tell if the fuel pump is the stock one or a walbro. thanks for any advice you can give me
Old Nov 17, 2006 | 08:49 PM
andifidie's Avatar
take off your back seat, and have a looksie. Bolsen has a great how-to for installing it, just follow the directions up to the point where you access it and youre golden
Old Nov 17, 2006 | 08:55 PM
stance's Avatar
Or listen to it, see if you can hear it buzzing ... you usually can hear Walbro pumps.
Old Nov 17, 2006 | 09:06 PM
BLKWIDO's Avatar
useally if you hear a high pitch whine, then most likely. If in doubt check it
Old Nov 17, 2006 | 09:45 PM
boscoyo's Avatar
Open it up and look for an army green fuel pump that says Denso on it.
edit: that would be the stock pump.^^^
Old Nov 17, 2006 | 09:46 PM
redevo8u's Avatar
ok i have the car tore down doing other mods and i cant turn the ignition on so if i take it out and look at it does it clearly say walbro on it or are there other thing to look for? thanks for your replies
Old Nov 17, 2006 | 09:49 PM
ApexVIII's Avatar
i had the same thing. but mine wines really loud so i know its walbro. and i went to the local mitsu and found out who owned it befor me and i contacted him and he told me what was on it and what still is. so if it wines then its probably a walbro
Old Nov 17, 2006 | 09:54 PM
boscoyo's Avatar
Not all after market pumps make noise. Open it up and see what you have.
Old Nov 17, 2006 | 09:56 PM
redevo8u's Avatar
i cant remember if it wined loud or not because i didnt pay attention to it. since i have it tore down i cant listen to it but i wanted to replace it now if i know it is stock. anyone have any pics of a stock pump compared to a walbro?
Old Nov 17, 2006 | 09:57 PM
boscoyo's Avatar
Old Nov 18, 2006 | 04:31 PM
FLAEVO's Avatar
Yes it does I just pulled mine out today,I put the buschur high flow in today.
I have the old upgraded pump in front of me and it says,Walbro gss342
it has pat# and made in usa also hope that helps.
NOMIEZVR4
Oct 17, 2022 04:15 AM
oscarquinones
E85 / Ethanol
Sep 2, 2013 12:28 PM
jeandsm
Apr 20, 2011 05:25 PM
twinturbogreg
Sep 28, 2010 03:00 PM
theflyho
Apr 17, 2007 07:49 PM
