Tranny screwed
Old Nov 19, 2006 | 12:15 AM
streetrace12's Avatar
Tranny screwed
I was driving to a budys house and the kid is a type s acura wanted to see how fast my car was, so like an idiot I get on it and when I shift into 2nd gear it was really hard to get in gear. It wouldnt go into gear so I just went to 3rd and cruised, when I went to downshift at the next light there was no 2nd or first gear, it was gone. So now I have no 1st or 2nd gear and I had to drive home with only 3rd 4th and 5th gears. Is my tranny blown or can I get those gears repaired? Has anyone ever heard of this before?
Old Nov 19, 2006 | 12:18 AM
RoadSpike's Avatar
locked out?
Maybe you just bent/snapped a shift fork. It seems probable at this point. Your tranny would be making many ugly noises if you shattered gears. Take it to a mechanic and get an estimate or the dealer.... if you dare
Old Nov 19, 2006 | 12:22 AM
Haha I really dont want to go to the dealer, no wierd noises just no 1st or 2nd gears at all, its like their not even there
Old Nov 19, 2006 | 12:36 AM
anybody else no what this could be or ever expirenced this?
Old Nov 19, 2006 | 06:51 PM
boosterclubevo's Avatar
probably synchronisers
Old Nov 19, 2006 | 06:55 PM
lcakes05's Avatar
are you joking. no way.
Old Nov 19, 2006 | 06:56 PM
lcakes05's Avatar
if you had bad synchros it would just grind evertime you put it in gear. you wouldnt get completely locked out.
Old Nov 19, 2006 | 10:06 PM
Steve@NoLimitmotors's Avatar
sounds like a clutch issue dude, kinda weird to just get completely locked out of nowhere. try putting it at idle or maybe with the car off. that or shifter cables but i cant see how they would get messed up
Old Nov 19, 2006 | 11:05 PM
EvOcHaRgeR's Avatar
I had the same thing happen to me where I was locked out of 1 and 2 but all it was a little metal clip for the shift cable thing. I just replaced it and I was done cost me like 50 cents. Not sure if you'll be as blessed.
Old Nov 19, 2006 | 11:25 PM
ONRAILS's Avatar
We were running 130ish in my buddy's sti and he went to grab 6th and grabbed reverse. after that it was like revers just wasn't there. Like it was gone. Didn't go in reverse or anything like it was never there. He ate every tooth off the gear.
Old Nov 19, 2006 | 11:45 PM
elhalisf's Avatar
does your shifter feel loose? if not, you most likey broke the pin that holds the 1st/2nd shift fork to the shift rail. this happened to me in 3rd/4th
drain your fluids, and the magent should catch the broken peice.
it is a fairly simple repair job. you can even buy the roll pin from the dealer.
i think scott at TTP has rebuilt these trannies before. ask him
Old Nov 20, 2006 | 08:44 PM
Shifter is loose, its like there is no 1st or 2nd gear, im not locked out, i got locked out then i pulled it into gear and after that 1st and 2nd were gone. Its jusy real loose, but 3rd and up are fine. Its really wierd, I need HELP!
Old Nov 20, 2006 | 08:47 PM
I asked scott he said I can come in but the only thing is I live in deerfield beach and it would suck to drive all the way to orlando with no 1st or 2nd.
Old Nov 20, 2006 | 08:53 PM
Ultimate CC's Avatar
that is definitely shifter fork, what year evo do you have, the 03s had an issue with this...
Old Nov 20, 2006 | 09:00 PM
05, how much did it cost you to fix?
Llew
Oct 14, 2015 03:14 PM
JDM EVO PANAMA
11
Dec 3, 2010 01:27 PM
raytrix
Driving Techniques
15
Oct 13, 2008 05:20 AM
CrackerJackToy
Sep 17, 2007 06:43 PM
KreepaEvoX
16
Jan 24, 2007 08:37 AM
