Buschur Racing 50 trim turbo kit......
Old Nov 22, 2006 | 11:53 AM
David Buschur's Avatar
Here's the scoop. There is a lot of demand for a 50 trim turbo kit. I've never used one but that is going to change.
I have a new turbo kit that I want to build. I need a car to do it on, so someone looking for a 50 trim kit, this is your shot at getting one on the car, tuned, cheap.
This is a non ballbearing turbo, so it is also not water cooled. It will use our cast/coated manifold. Very nice, simple kit. I should be able to keep the cost down on them to under $2,000 complete. I am waiting on pricing for the turbo so I can get it exact but under $2,000 is what it looks like.
I'd prefer a car with our 3" turbo back on it and an AEM EMS, that's my only two requirements. If you have stock injectors you will probably need to upgrade to an 880 cc or so.
I will install it, tune it and make whatever is needed for lower i/c pipes for the install.
Contact me via PM if you are interested.
Thank you,
Old Nov 22, 2006 | 11:59 AM
Blue Evo 8's Avatar
Can a 50 Trim EVO run 10's?
Old Nov 22, 2006 | 12:19 PM
Well, looking at your dyno chart, I'd hope it could run 10's.
This is not a typical 50 trim turbo but I am not going to release all the information until after I can post results and pricing.
Old Nov 22, 2006 | 12:27 PM
*sam*'s Avatar
What the difference between BB 50 trim & NON BB 50 trim?
Old Nov 22, 2006 | 12:31 PM
xLaNcErEvOx's Avatar
if everything goes well on you new turbo kit build, then put me on the groupbuy list if you meet you -$2000 cost.
Old Nov 22, 2006 | 01:10 PM
I guarantee you the kit is going to be under $2,000, gaurantee. How much under is yet to be seen.
The question on the BB difference, well, one is ballbearing and one is not.
Old Nov 22, 2006 | 01:13 PM
Blue Evo 8's Avatar
DUUHHHHHHH
Old Nov 22, 2006 | 01:18 PM
KevinD's Avatar
ball bearing turbos spool considerably faster. journal bearing turbos are cheaper.
Old Nov 22, 2006 | 01:28 PM
It's interesting that you say that KevinD. I thought the same thing. I was educated differently this week.
Old Nov 22, 2006 | 01:32 PM
*sam*'s Avatar
Wow really, You must be a rocket scientist or something to figure that one out.
Somebody also Pm me that the BB turbo spool quicker, and has a longevity over NON BB turbo
Old Nov 22, 2006 | 01:54 PM
Well I am pretty freaking smart but I don't think I'd say I am rocket scientist smart. I'm smart more along the lines of a gynecologist, in that depart let me say, I am really- really smart. I can spot them, identify them, treat them and hell sometimes I even name them. I also know they do not have the ballbearing option but many have a sleeved bearing option and sometimes the sleeve should be much tighter for proper clearance. I've seen those with and without the water cooling option, more commonly refered to as "squirters", they can be quite messy so make sure you use a drip pan when doing an install on that type. The spool up can vary, this will depend on the bore and stroke used to try and get it going. The really nice thing is the map for them is quite easy to follow and there is no actual pressure ratio, most can take whatever you throw to them. In actuality most people will never use it to its full potential. This is kind of sad as a lot of times your buddies will end up using it too, sometimes a few guys at a time will take it out to beat on it.
Yeah, I am pretty freaking smart when it comes to those types. I'm not a rocket scientist though.
Old Nov 22, 2006 | 02:00 PM
lexat20's Avatar
worthless w/o pics
Old Nov 22, 2006 | 02:02 PM
lexat20, Dude NOW THAT IS FUNNY!!! HAHAHAHAHAHAHAHA
Old Nov 22, 2006 | 02:03 PM
*sam*'s Avatar
Well that the type of answer I wanted. Other than that pathetic comment"One is BB and the other is not" No sheit sherlock
Old Nov 22, 2006 | 02:10 PM
gaulrich2003's Avatar
Do u have an estimate on the length of time you will need the car?
