evo 8 turbo vs evo 9 turbo
Old Nov 29, 2006 | 12:08 PM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
Originally Posted by 05WhiteEVO8
FYI the install kit can be had on turbochargers.com for 150 bucks.
did not know that...you indeed do learn something new everyday
P.S. someone might wanna alert buschur to that then cuz thats where i got the price.
Old Nov 29, 2006 | 12:27 PM
chaz517's Avatar
lol warralontish, i like that, no its all good, it wud make no sense if i eventually was goin for say 500 hp but my goal is just 300-320 whp
150$ for the kit not bad at all, i wonder if i can find an ix turbo that some1 is trying to sell on here for cheaper, but then again i never ever trust a used turbo
Old Nov 29, 2006 | 12:30 PM
big_huff's Avatar
you can make that withou upgrading your turbo. do you have any mods yet or are you still stock?
Old Nov 29, 2006 | 12:34 PM
chaz517's Avatar
i just have a mail in flash boost controller set at stock level, and drop in, after x mas bushur tbe with magnaflow and fuel pump and custom flash by al
Old Nov 29, 2006 | 12:36 PM
big_huff's Avatar
get your exhaust and dont upgrade your turbo. take the money that you were going to use to upgrade your turbo and buy cams and tune it again and turn up your boost a little bit and you should make your desired whp.
Old Nov 29, 2006 | 12:39 PM
tvbf1's Avatar
The IX intake housing is bigger and the compressor wheel are magnesium.
For more info, contact Gruppe-S. They installed it on one of the customers car. Give them a ring.
Old Nov 29, 2006 | 12:40 PM
chaz517's Avatar
ya u think thats a better route? how much are hks 272? like 1000? and isnt iinstallation a lot for cams? i sure know i cant put them in lol
and gruppe-s thanks for the info
Old Nov 29, 2006 | 12:45 PM
elhalisf's Avatar
the compressor wheel is not magnesium. its the same as the evo 8 one. the only difference is that the compressor housing is bigger on the 9.
i am opening up an evo 9 turbo tomorrow and will compare it to the evo 8 one in my car.
Old Nov 29, 2006 | 01:01 PM
GPTourer's Avatar
Originally Posted by EVIL_EVO_VIII
Ppl that have 05s and have added this turbo have seen an additional 25whp gain.
Where can I find proof of that?
Old Nov 29, 2006 | 01:05 PM
Warrtalon's Avatar
GPtourer, search around - several have added a IX to an 05 and made 20whp or so, verified by dynos and track improvements.
Rcheung, the turbine housing is not bigger, just the compressor housing. The 10.5 you mention IS the turbine housing - 06s have the same 10.5 turbine housing as the 05s.
OP, you can easily make that small amount of power with your stock turbo - no need to upgrade. In fact, you can make far more power than that easily without touching your turbo.
No magnesium internals - that is false unless referring to a JDM version.
Old Nov 29, 2006 | 01:32 PM
chaz517's Avatar
allrite so i guess no upgrade is encessary thanks 2 every1 for the input
Old Nov 29, 2006 | 01:43 PM
Pd1's Avatar
Pd1
Even $150 for the "install kit" is a rip-off. It can be purchased from MitsubishiParts.net for about $80 shipped.
Here's everything you need:
Quantity Part # Description List Unit Price Price
1 1310A171 Pipe,t/c Water Re $11.00 $8.38 $8.38
1 1310A248 Pipe,t/c Water Fe $11.00 $8.38 $8.38
1 1515A057 Fitting,t/c Air O $49.75 $37.91 $37.91
1 MR281085 Gasket,t/c Air Ou $3.60 $2.74 $2.74
2 MF660063 Gasket,clutch M/c $1.03 $0.79 $1.57
1 1225A042 Tube,t/c Oil Feed $10.35 $7.89 $7.89
4 MF660065 Gasket,cooling Wa $0.75 $0.57 $2.29
2 MF660064 Gasket,a/t Case $1.22 $0.93 $1.85
Subtotal: $71.02
Shipping: $9.95
Old Nov 29, 2006 | 01:52 PM
Ultimate CC's Avatar
Like others have said, there are many mods you can do before you upgrade your turbo...alky alone will net you over 20whp...
Old Nov 29, 2006 | 01:54 PM
Warrtalon's Avatar
PD1, which one of those is the compressor outlet pipe?
Old Nov 29, 2006 | 02:12 PM
Pd1's Avatar
Pd1
That's the most expensive piece:
1515A057 - Fitting,t/c Air O $37.91
