evo 8 turbo vs evo 9 turbo
The IX turbo on an VIII does not spool faster than the VIII turbo. The earliest I could get mine to hit 21psi was 3200rpm with my gears set to +1/-1.
Here's a link which contains the curve as registered by my MAP sensor with the gears set to -2/-2.
The curve looked very similar at -4/-1 as well. Peak boost hits at about 3600rpm. Here's the graph using -4/-1.
you should always do the basic bolt-ons like a turbo-back before upgrading your turbo IMHO. i'd do at least TBE, pump, flash, MBC, and cams(even an intake) before thinking of a turbo upgrade.
I HAVE N EVO 9 TURBO FOR SALE! : https://www.evolutionm.net/forums/sh...d.php?t=240738
Deano_Engineer_
Mar 6, 2014 05:57 AM
Evolution8Blue
12
May 5, 2006 11:34 AM
