evo 8 turbo vs evo 9 turbo
for people with experince
between the evo 8 and 9 turbo. does the 9 turbo spool faster or slower then the 8 turbo.
does it hit full boost sooner or later the the 8 turbo. how much later???
does it tapper boost as much, less, or more then the 8 turbo??? if it tappers how bad iis it. what kind of boost are you holding at redline. what boost are you running.
thanks
thanks
Here are some more interesting links:
https://www.evolutionm.net/forums/sh...d.php?t=184384
https://www.evolutionm.net/forums/sh...d.php?t=136715
Originally Posted by nvr2fast
Does anyone know what has to be changed (in regards to timing or fuel mapping, like in Ecuflash) if you switch from a Evo8 to Evo9 turbo?
I would think you need to increase the fuel, and decrease timing, to accomodate the slightly larger turbo to prevent detonation? Or am I completely off?
Originally Posted by sonicnofadz
No. The turbo's flow characteristics are almost identical. Any extra air flow will compensated automatically be the MAF sensor + ECU adjusting the fuel levels. You may want to stick in a better fuel pump if you are running cams or higher boost. A custom flash is always a good idea to extract more power, but in this case it is not required.
I guess from what you said, there might be small gains, but most will be auto-compensated by the ECU anyway.
Originally Posted by nj1266
1. Cams work by shfiting the power curve from mid-to-low range to the top end. I really do not want to do that on my daily driven car. I can go with 264 cams to compromise, but IMO 272 cams are the best.
HKS 272/272's at 0/0 idle pretty well. I tuned a car last night with buddy club 272/272's and cam gears at -2/-3. When it came to me it was a little choppy. After I tuned it via a flash it purrs like a kitten. It's not really a big secret on how to make them idle well, although every car is a little different. Ign timing changes and idle RPM changes can go a long way to making a smooth idle.
Originally Posted by chaz517
ya u think thats a better route? how much are hks 272? like 1000? and isnt iinstallation a lot for cams? i sure know i cant put them in lol
and gruppe-s thanks for the info
Originally Posted by Sully 18
like 300 to put in...but its not hard put them in yourslef
I just finished putting mine in and came by from the dyno.
It is incredible how much FASTER the evo 9 turbo spools up over the 8. that is the first thing i felt. and the power transition is much smoother, and it holds more boost to redline. i love this turbo!
That's what is reported in this post as well:
https://www.evolutionm.net/forums/sh...5&postcount=30
