is your Greddy Type-S making your car stumble?
Old Apr 3, 2005 | 10:32 PM
ec999's Avatar
and this is only stoping.... or slowing down with the clutch in
Old Apr 3, 2005 | 10:37 PM
solarxclipse's Avatar
had mine for almost 2 years now with both springs on and recirculating. never had any stalling issues what so ever. i got my stock airbox with hks drop in filter though.
Old Apr 3, 2005 | 10:38 PM
rlazer5000's Avatar
Hey man, i completely forgot that EVO Moto had a section on the greddy single spring mod...... http://www.evomoto.com/tech_info.php?tPath=1&tech_id=7 ......that should clarify a little bit!
Old Apr 3, 2005 | 10:43 PM
ec999's Avatar
btw it's not surge if im running up on a light with vaccum....
"Turbo surge or stall occurs under heavy load conditions where boost pressures are high. The main cause is generally an imbalance of pressures between the turbine side and the compressor side of the turbo. When the forces on the turbine are no longer strong enough to drive the compressor side of the turbo adequately, stall occurs"
Old Apr 3, 2005 | 10:48 PM
ec999's Avatar
so would it be wise to turn it in a few more to cure the stumble?
Old Apr 3, 2005 | 11:01 PM
6one9EVO's Avatar
i also did the single spring mod on my type s and after that i had no problems. After adjusting the screw it gets louder with every turn you make. I put about 7 turns on mine. sounds and works great. How many turns did the rest of you guys do?
Old Apr 4, 2005 | 05:24 AM
rlazer5000's Avatar
According to EVO Moto's type-s mod, they said to turn the screw 2-3 times.....also, they had a way to make the whistle sound of the BOV more distinct somehow......check it out and see what u guys think! I'll be doing the single spring mod tonight and ill let u guys know how it goes!
Old Apr 4, 2005 | 07:23 AM
NocturnalEVO's Avatar
i've had the greddy type-s and it stumbled no matter how much i adjusted it.
now i have the HKS which holds boost noticably better and I didn't think it stumbled at all, up until yesterday for some reason it would stumble a lot.
Duno what the problem is
Old Apr 4, 2005 | 04:00 PM
ec999's Avatar
well i turned in 7, 6 threads out, still dips coming to a light
Old Apr 4, 2005 | 04:13 PM
rlazer5000's Avatar
Well i just did the single spring mod to my type-s about an hour ago and i think it worked.....i dont know, i drove it a round for a few minutes and the sound is a little more faint, but still pretty cool. Like ec999, my car still stumbles a little bit when im coming to a stop.....i think u just gotta turn the stud a little more in order to make it tighter. Oh well, im gonna figure it out later on!
HyaboostaIX
13
Apr 3, 2011 04:27 AM
03evo8kevin
20
Aug 2, 2009 09:39 AM
TogueMonster
19
Oct 27, 2006 01:07 AM
pgmike
Lancer Aftermarket Forced Induction Tech
14
Dec 17, 2004 09:50 PM
hel_if_ino
13
Aug 20, 2003 04:57 PM
