TTP: dyno plot for your latest setup
Old Dec 10, 2006 | 06:05 PM
  #31
Ultimate CC's Avatar
that has been done several times...
Old Dec 10, 2006 | 06:21 PM
  #32
C6C6CH3vo's Avatar
I would like to see an evoscan log with his car in 3rd gear, just the excel file with a good counter vs rpm, that would be impressive
Old Dec 10, 2006 | 06:27 PM
  #33
C6C6CH3vo's Avatar
What about nitromethane? One of these days I'll spray a little of this with the MeOH just to see the results, anybody try this yet?
Old Dec 10, 2006 | 06:29 PM
  #34
For proof, how about that you have an evo9 turbo in your car, starting to believe me yet Scott...
Old Dec 10, 2006 | 06:44 PM
  #35
C6C6CH3vo's Avatar
I dont think the evo 9 turbo will give much without mivec and the 9 ecu mapping. To levels of 130mph, if a 9 turbo alone can push it, then why not try it with an 8 16G?
Now if he's got mivec mapping and ecu in there thats a different story dude
Old Dec 10, 2006 | 06:46 PM
  #36
its been proven to give a mph or two in the traps...
Old Dec 10, 2006 | 06:48 PM
  #37
Evoryder's Avatar
...mysteries
Old Dec 10, 2006 | 07:03 PM
  #38
inco9nito99's Avatar
bad attention is still attention .
Old Dec 10, 2006 | 07:04 PM
  #39
anjapower's Avatar
Originally Posted by Ultimate CC
I am not discrediting anything you have done Scott, regardless of how you got to a 10.9 its still a mf 10.9 on stock turbo which is mf amazing...the parts alone don't get you to run times like that its also the driving and hats off to you for some great driving as well because with that sort of power its not easy...my only lack of respect is your lies about your setup, honestly nitrous is not a big deal and it shouldn't be hidden...the whole 10.9 in your sig is very misleading to noobs who see it as you doing it on stock turbo alone...nitrous is a huge power adder and needs to be noted...I in no way want to take away from what you did but as you requested with me and would not stop posting until I changed my sig, I would like the same from you...hats off to your run and if you take this as trolling so be it...moderators please review...
he has stated that he doesn't use nitrous.
Old Dec 10, 2006 | 07:05 PM
  #40
Find me the post...
Old Dec 10, 2006 | 07:06 PM
  #41
TrinaBabe's Avatar
I used to have misfire problems bad enough that they plugs would only last through 1st and half of second gear before they bombed. My problem was the stock ignition couldnt handle it I since "upgraded" to stock DSM stuff. Problem was cured.
  #42
you got that right, 39 pms today and counting...
Old Dec 10, 2006 | 07:10 PM
  #43
anjapower's Avatar
Find me the post...
it was in the mike1023 thread that was locked/closed and then deleted.
Old Dec 10, 2006 | 07:22 PM
  #44
TTP Engineering's Avatar
You my friend have never been more wrong, you know the truth, there is a bottle in your car and im calling you out on it, there are more people close to you that have let the cat out of the bag then you could imagine, I will not disclose their names out of respect but the two clowns you mentioned are not who I know, any moderators that think I am lying can check my pms for proof...check it...
There was a reason why we decided not to further respond to allegations. People push push push and when they finally get their "satisfaction", it is never good enough. It is a neverending circle of death that does not bring anything to evom but additional work for the moderators. I think it is time you cease and desist these allegations as you have already caused enough extra work for the mods to clean up as it stands.
If you cannot keep matters on a factual basis, please refrain from posting in any threads regarding TTP.
Old Dec 10, 2006 | 07:27 PM
  #45
this means....nitrous does not need to be in your trunk to be run ahaha...you know how many street racers run the lines inside the car and have the bottle chilling in the back seat haha...l3 weeks ago I was at the track and these guys rented a car from enterprise and where spraying a 150 shot in a grand marque running low 14s and you would have never know there was spray in the car...Scott all I ask of you is to change your signature as you did of mine, put like call for the mods to get you to 10s, something...
