TTP: dyno plot for your latest setup
Old Dec 11, 2006 | 02:49 PM
  #76
C6C6CH3vo's Avatar
Amyl nitrate
Originally Posted by Brian_H
I heard his tires are in fact filled with helium.
Good job.
helium jihad
Old Dec 11, 2006 | 02:59 PM
  #77
C6C6CH3vo's Avatar
Originally Posted by TTP Engineering
Abner is correct.
We do not use any snow performance pumps.
Dan probably thought it was the snow pump not only for the recognized Sureflo, but they also use the same looking compression fittings and tubing.
I tell you one thing, I talked to the snow engineer and he said that they're comming out with a new controller for Evo's - this one will be 2D, and will handle the current of a 220 psi pump.
Whats so neat about this?
As boost increases, so does atomized droplet size, especially with larger nozzles - a higher pressure output from pump will provide much better atomization, especially at 28psi. And furthermore you may also get the same flow with one size smaller nozzle for even smaller dropplets (dont underestimate surface area).
Old Dec 11, 2006 | 03:02 PM
  #78
Ultimate CC's Avatar
the removed sticker off the pump was a hint...
Old Dec 11, 2006 | 03:10 PM
  #79
SlowCar's Avatar
Originally Posted by C6C6CH3vo
Amyl nitrate
helium jihad
hmmm......vcr cleaner/poppers
Old Dec 11, 2006 | 07:28 PM
  #80
TTP Engineering's Avatar
You mean this sticker hint?
http://www.shurflo.com/pages/new_ind...0-543-238.html
Old Dec 11, 2006 | 08:48 PM
  #81
94AWDcoupe's Avatar
Alkycontrol has had a progressive controller for 2 years. The pumps test at 250psi on the bench. The controller varies the voltage to the pump. The jet allways sees the 250psi. these pumps are pulse pumps. They sound similiar to an injector turning on and off. The varied voltage to the pump works fantastic. what it does is control the pulse speed. You really need to see the spray in action to understand. Alkycontrol is really the finest kit maker in this feild. For something so important why wouldn't you go with the best and most experienced? Unfortunately he has a supply and demand problem and can only supply AMS with kits. And even they cat get all the kits they can use.
Old Dec 11, 2006 | 10:37 PM
  #82
SlowCar's Avatar
I'm
Old Dec 12, 2006 | 06:19 AM
  #83
DRFTKNGG's Avatar
Originally Posted by Rcebowl
just wondering do you have proof that he's running n2o? i mean besides his numbers?
do you KNOW have you seen the car in person and seen the n2o set up?
I have seen it.
You wont find it now though. As it is fully hidden in the quater pannel. But before it was in trunk where he had to open the trunk to open the bottle, which is when he got caught early one morning.....
10's is still impressive though. It's not easy to get all these variables to work in unison for a great pass.
Old Dec 12, 2006 | 06:39 AM
  #84
BADEVO's Avatar
Originally Posted by DRFTKNGG
I have seen it.
And the wheels of the drama keep turning..... Ruben do you KNOW for a FACT the car is running nitrous or are you going off of he said she said ????
Old Dec 12, 2006 | 08:47 AM
  #85
Yeah I have a 10lb bottle in the quarter panel.
Why am I not surprised that someone from evom actually thinks you can hide a bottle in the 1/4 panel. This is ridiculous. You cannot even fit a shurflo meth pump in the 1/4 panel.
There is no nitrous on the car. Plain and simple.
Thought it was an interesting idea to create a little mystery, but I soon realized that all it does is draw out the haters from the woodwork.
Here is the deal. We have experimented with different fuels, different injectors and different delivery of said fuels. We were willing to take the risks on our own $35000 car. Unfortunately until these systems run 100% flawlessly, we do not intend to offer this particular stage for sale. Last thing we need is something to go wrong and lose a few motors.
I am sure it can be appreciated that we are not just here to collect money and install unreliable injection systems and safety questionable fuels in customer cars. Until we know that we can make a safe and reliable setup for ourselves- complete with safeguards, we won't even think about experimenting with other's pride and joy.
Old Dec 12, 2006 | 08:53 AM
  #86
BADEVO's Avatar
What else can you say. The question was asked, he replied. Until he gives you reason to say otherwise I say take him at his word.
I'm interested in this "alternate fuels" thing more then anything else.
Old Dec 12, 2006 | 09:14 AM
  #87
94AWDcoupe's Avatar
Thanks for clearing that up Scott . Maybe if ten people repost. It will sink in.
Old Dec 12, 2006 | 09:32 AM
  #88
Jasil's Avatar
Thanks for the update!! Now all of the Nitrous accusers will go away.
Old Dec 12, 2006 | 09:56 AM
  #89
Nesiop's Avatar
Didn't CB run in the 10's without nitrous also... It is doable... just takes the right setup and free driver mod...
Old Dec 12, 2006 | 09:57 AM
  #90
CB was not at full weight though
