Spark Plug question
Old Dec 12, 2006 | 11:39 PM
WickedIXMR's Avatar
Spark Plug question
Today i bought some ngk br8es plugs for my 9 thinking theyll be the same as the 8's. But found out that the 9 plugs are different sizes. I want to go with a 1 step colder plug on my setup. I will be running meth and high boost so i want plugs that are colder than stock. Which Ngk's do you guys recommend? Also the stock 9 plugs are ILFR7H I did search but didnt find what i wanted to know.
Old Dec 13, 2006 | 12:23 AM
andyktlee's Avatar
Pocket Mo
The NGK 8s will be cold enough with meth.
Old Dec 13, 2006 | 12:35 AM
tmodlin's Avatar
Search 'spark plugs' most of the hits will go for the 9 setup. They are longer than the 8s, so the 8 plugs will NOT work correctly.
I cant give you a part number but the MIVEC head definitely requires a whole different spark plug. Apparently the 9s are more popular than the 8s though. Atleast on EvoM.
The 9s have a longer plug and I know that there are colder versions out there. Either search like I said, or wait til someone replies again.
They are out there man, just search around.
Old Dec 13, 2006 | 12:38 AM
tmodlin's Avatar
But are they long enough for the IX head? The MIVEC requires a longer plug reach.
Old Dec 13, 2006 | 10:16 AM
cbrtrx's Avatar
do not use the shorter plugs in the evo 9 head, one heat range colder for the evo 9 are the denso ikh24 those are the 8 heat range, they cost around $11 each
Old Dec 13, 2006 | 10:35 AM
Steve@NoLimitmotors's Avatar
we have denso iridiums in stock for the 9, 1 step colder, for 50$ let me know
Old Dec 13, 2006 | 11:43 AM
WickedIXMR's Avatar
NGK 8's dont represent the size it just represents the heat level.
Old Dec 13, 2006 | 12:02 PM
skiracer's Avatar
Call NGK customer service directly. I talked to the guy there and he's pretty knowledgeable on what plugs to use depending on your mods:
http://www.ngksparkplugs.com/contact...000&country=US
Technical Support
hours: 8:30am - 5:00pm Monday-Friday EST
tel: 1-877-473-6767 prompt #2
Old Dec 13, 2006 | 01:16 PM
WickedIXMR's Avatar
^^^thanks alot!
Old Dec 13, 2006 | 02:01 PM
Chris@nolimitmotors's Avatar
I run the one step colder denso's in my car with no problems. I am running meth and 30psi.
Old Dec 13, 2006 | 02:28 PM
C6C6CH3vo's Avatar
Running methanol, in a way, kinda defeats some of the purpose of running the colder plugs. I run BPR7IEX at 26 PSI, with 0.025 gapped,on stock IGN spark and wire, spraying 625ml/min or more of methanol.
Think of it as running methanol may allow you to run one step hotter plugs
But if I'm wrong on this everybody, by any means correct me - evo power is a learning curve.
Look at it this way, if your not detonating with the 7 range (even with 350whp but with racegas or methanol) then there is no reason to go to a colder 8 - the plugs got to be somewhat hot so they can remain clean
Old Dec 13, 2006 | 03:15 PM
tmodlin's Avatar
Yes, I know this. Thanks for pointing it out.
slipperychicken
Feb 27, 2016 10:27 AM
benIX
Aug 2, 2013 04:15 PM
pinoy6969
Pacific Northwest
Jul 27, 2012 12:53 PM
Dannievo
Mar 28, 2009 03:52 PM
silver evo8
Aug 7, 2007 04:20 PM
