Twin Pump Install Pics!!
Old Dec 16, 2006 | 08:09 AM
QuickOne's Avatar
Looking good. Any chance larger Denso pumps might fit this setup? Or could be setup to fit?
Just not a huge fan of walbros is all...
Old Dec 16, 2006 | 09:51 AM
FullBlown's Avatar
I might try to design it around the densos but well have to see.
Old Dec 16, 2006 | 11:19 AM
FullBlown's Avatar
Originally Posted by Fourdoor
Can this assembly be easily modified to work in a fuel cell? I have thought about going to a large fuel cell, but I don't want the noise of an external pump.
Also, I note that your assembly uses the space ocupied by the stock fuel filter for the second pump. I assume you have an "in line" style fuel filter on you supply line to the fuel rail?
I have a bunch of off topic questions/speculation that I will put in another thread and link to here: https://www.evolutionm.net/forums/sh...70#post3762570
Keith
im sure you can but you would have to have some sort of baffle for the tank itself. I am using an inline fuel filter.
Old Dec 16, 2006 | 12:09 PM
Drifto's Avatar
Any worries about current draw being too much for the stock wires? Set up looks really great
Old Dec 16, 2006 | 12:27 PM
SwiftEVO's Avatar
You could use a relay that is wired into the stock harness So that when it gets power it flips the relay, and run a power wire straight from the battery and just ground it somewhere on the chassis.
--Josh
Old Dec 16, 2006 | 12:38 PM
chongo's Avatar
thanks for the info. clean write up
Old Dec 16, 2006 | 12:41 PM
Torre from Va.'s Avatar
Nice !!
Old Dec 16, 2006 | 12:48 PM
GT35MR's Avatar
I'm going to be running E-85 when I get back do you think this is the best fuel pump setup for it?
Old Dec 16, 2006 | 01:11 PM
FullBlown's Avatar
Id run the 255 walbros with this dual pump assembly, should be plenty of fuel for the E85.
Old Dec 16, 2006 | 09:42 PM
FullBlown's Avatar
Like mentioned, the current draw is the same for 1 pump, the other pump must be wired on some kind of relay that is triggered by an output like the aem ems or pressure switch. I would not try to run both pumps off of the stock wiring. there is no need for that. I will post up a diagram asap i promise.
Old Dec 17, 2006 | 02:37 PM
FullBlown's Avatar
Here is the wiring diagram for the second pump.
Old Dec 18, 2006 | 05:56 PM
RAM1320's Avatar
Do you have these pieces for sale? Complete kits with lines and hardware?
Old Dec 18, 2006 | 06:19 PM
FullBlown's Avatar
Yes i can have a full kit for you. I am a earls dealer and can supply all the fittings and line you may need.
Old Dec 18, 2006 | 06:54 PM
ray3328's Avatar
Good looking setup. Great write up.
Old Dec 19, 2006 | 06:10 PM
FullBlown's Avatar
Thanks bro, ok they are in stock ready to ship!! please follow this link
https://www.evolutionm.net/forums/sh...64#post3773564
