Modifacations to the block to fit 2.3 crank
Old Dec 18, 2006 | 11:49 AM
ONRAILS's Avatar
So my engine builder just called me saying that they needed to modify the case to fit my stroker kit.
BTW they left a message now i cant get ahold of them. I think this is total bs though i've never herd of anyone having to modify anything for a 2.3 kit.
Old Dec 18, 2006 | 02:05 PM
thebluesky's Avatar
Case???? If you mean block, then yes,they may have to bore it out unless you got a stock bore kit. Only other issue you could have is having to remove the balance shafts completely if the won't clear the rods during movement.
Old Dec 18, 2006 | 04:05 PM
value's Avatar
What stroker kit is it?
Old Dec 18, 2006 | 04:41 PM
itzwolf's Avatar
On my AMS 2.3 stroker, the block is notched for the big **** Oliver rods
I wouldn't sweat it.
Old Dec 18, 2006 | 04:55 PM
ZyBeR's Avatar
You need to drill it to 85.5mm (95% of the times)
Also might need a line honing (5% of the times)
Always remove the balance shafts, you don't need them. The little extra vibrations wont' make any harm. When removed you will get slightly hight oil pressure and a easier reved engine and no risk of the rods touching them.
Make sure they do it the right way directly so you don't have to re-do it all again.
Old Dec 18, 2006 | 05:48 PM
SwiftEVO's Avatar
We had to clearance my block too. Im running the manley I beam rods.
--Josh
Old Dec 18, 2006 | 06:18 PM
CO_VR4's Avatar
As you can see from the above, some rods have a different (larger) big end configuration than others. If the rotating assembly won't rotate due to insufficient clearance, you have to either modify the block or the rods by grinding the necessary clearance. This is more common with making a "2.3" from a 2.0 than if you start with a 2.4 block that is already built for the 100mm stroke crank.
Old Dec 18, 2006 | 06:27 PM
SwiftEVO's Avatar
I did the 4g64 block and still had to clearance it.
--Josh
Old Dec 19, 2006 | 12:08 AM
GTREVO's Avatar
It depends on which rod you're running...Didn't have to clearance mine with the PAuter rods..
Old Dec 19, 2006 | 02:06 AM
ONRAILS's Avatar
I found out what it was. Block has to be clearanced. The shop just left me a voice mail that was way off of what was going on.
Wish SBR had told me the manleys had to be clearanced
Strictly Modified
Mar 13, 2010 08:50 AM
jid2
24
Dec 7, 2009 09:17 AM
jdm4g63tgalant
For Sale - Cars For Sale
Jul 24, 2008 01:20 AM
r34p3rex
Automotosports - Illinois
14
Apr 21, 2008 03:39 PM
Johnboy1065
Apr 2, 2007 10:48 PM
