boost and going to the track
Old Dec 19, 2006 | 11:01 AM
shinnster's Avatar
Here's my question.
I'm tuned at 21 psi on 93 octane making 304 at the wheel.
I'm planning on going to roebling road raceway this is the first time i've been to the track since tunning.
Will it be ok if i drop down the boost to about 19 psi without retuning and still be safe for the track or should i get retuned for 19 psi.
Old Dec 19, 2006 | 11:07 AM
Smike's Avatar
Run 21 psi if that is what you are tuned for. Why do you want to run lower?
Old Dec 19, 2006 | 11:09 AM
shinnster's Avatar
just trying to be conservative. I basically want that margin of safety expecially since i will be going full on for about 20 minutes at a time.
Old Dec 19, 2006 | 11:13 AM
Smike's Avatar
Conservative should already be a part of your tune (dependant on who tuned your car - and for what it was tuned for street/drag/track). If you want some more knock safety pump some 100 oct unleaded in.
Running lower boost will make you tune richer - you tuned for more air+fuel, take out the air comp. and its just more fuel.
Old Dec 19, 2006 | 12:02 PM
Jeff_Jeske's Avatar
That all depends. Sometimes running less boost will cause the car to run leaner.
21 PSI is nothing the stock FMIC won't heat soak at that PSI especially at high speed with high air flow.
Old Dec 19, 2006 | 01:01 PM
shinnster's Avatar
how does lowering the boost cause a lean situation?
Old Dec 19, 2006 | 01:04 PM
Warrtalon's Avatar
The MAF will detect much less airflow and thus inject less fuel. If you are in different load cells that weren't tuned to the optimal AFR, then it could happen.
21psi is conservative already - just toss in a few gallons of 100oct or something, but you don't need to turn down your boost.
Old Dec 19, 2006 | 03:38 PM
evorace's Avatar
What engine management are you using?
Old Dec 19, 2006 | 03:54 PM
shinnster's Avatar
ecutek reflash
tuned by topspeed in atlanta
Old Dec 19, 2006 | 04:10 PM
evorace's Avatar
Then it is still based on the stock o2, knock, maf, iat sensors, etc to determine fueling and spark advance. I wouldn't worry too much about it. Just keep an eye on the coolant temp and make sure the car doesn't overheat. If you want some added insurance, put in some higher octance gas. But I think 21 psi will be fine for lapping. Your car doesn't know if its lapping or just running down the road so if the tune is correct, in theory, there should be no consequences to keeping the boost set at 21 psi.
Old Dec 19, 2006 | 04:30 PM
RazorLab's Avatar
21 is fine if the tune is good. That is my low boost setting at the track.
Old Dec 19, 2006 | 04:48 PM
spdracerut's Avatar
I'd just put in a couple gallons of 100 octane with the 93 to give you the 'safety margin'. No need to mess around with the tune.
I'd be more worried about the brakes! Put in some fresh fluid! And oil... and drivetrain fluids, etc.
Old Dec 19, 2006 | 05:16 PM
recompile's Avatar
NOS Octane Boost FTW
6466Animal
Dec 15, 2015 11:32 AM
jshkaz
Sep 26, 2013 06:09 PM
rartist
Mar 22, 2011 08:09 AM
05VIII
Dec 2, 2010 06:43 PM
ballistic speed
11
Dec 16, 2005 07:13 AM
