I hit 24 psi On Stock Setup
Old Dec 20, 2006 | 03:48 PM
3SgteGuru's Avatar
Ok I just confused myself, I have a TBE from AMS and Greddy profec B-spec Boost controller its not hooked up I gave it power and vaccum but i have it off and the selonoid isn't installed. I am still using the Stock boost Selonoid the vaccums and Every thing are untuched. I just got the vaccum from the Boost gauge in on the Sports meter package. So anyway, I decided to go though some of the options and I found how to read the Peak boost, it says 1.7 which is 170 kpa so if you calculate it right 170 kpa comes out to 24 psi !!!! I am not trying to brag, this is a problem if i am realy hitting 24 psi. Personaly I am doubting the boost controler measuring abilites, but its kinda hard to drive at WOT and watch a boostmeter. Now here is another thing I never almost never floor it. Like usualy I just push till satified, Evos are kinda fast you know.
Old Dec 20, 2006 | 03:55 PM
YogSaahoth's Avatar
Veteran: Army
those IX turbos are the *****
Old Dec 20, 2006 | 04:01 PM
evotico's Avatar
Yeah the 20g's turbo are sweet. Trying to get a used one to swap out my 16g.
Old Dec 20, 2006 | 04:36 PM
sammyKiller's Avatar
20g? Evo 9's dont come with 20g's, do they? I just thought it was 16g sized with a larger turbine clip.
Old Dec 20, 2006 | 04:39 PM
PhoenixEvo's Avatar
they r 16g's
Old Dec 20, 2006 | 04:43 PM
Warrtalon's Avatar
Um, yeah, that's what can happen if you install a TBE with nothing else - it reduces backpressure, which can cause boost spikes. You aren't supposed to install nothing but a TBE.
Not sure what evotico is talking about...IXs don't have 20g's, and 20g's have nothing to do with this topic anyway.
Old Dec 20, 2006 | 04:50 PM
spdracerut's Avatar
Cold weather will do it. With my completely stock 05, it will spike to 1.5 bar in ~80 degree weather, ~1.6 in ~65 degree weather, and it hit ~1.65 a couple days ago in ~45 degree weather.
On my Nissan, when it got cold, I always had to adjust my EBC down.
Old Dec 20, 2006 | 05:14 PM
AlwaysinBoost's Avatar
more then likely your only hitting 24psi for a few seconds and thats depending on the gear.
if you're tuned for it then it shouldn't be a problem, if not then you should hook up an MBC, if your not going to install that EBC, and turn your boost down.
Old Dec 20, 2006 | 07:13 PM
3SgteGuru's Avatar
So A tune Will Fix this, I have the Boost controler and Fuel Pump, I just didn't want to Screw anything up my leaning out or running way to rich.
Old Dec 20, 2006 | 07:15 PM
3SgteGuru's Avatar
I can Tune The EBC, but I will just get it done when i get the car tuned, for now i will drive with a lighter foot.
Old Dec 20, 2006 | 09:17 PM
Warrtalon's Avatar
No, a tune won't have anything to do with your boost being too high. That's why you have a boost controller. You should just have an MBC on there with the boost turned down, but if you must use an EBC, then that should also be on there right now with the boost turned down.
Why are you waiting until the tune? You need to turn the boost down, and then when you get tuned, set the boost where you want it. The fuel pump is not relevant.
Old Dec 21, 2006 | 04:56 PM
3SgteGuru's Avatar
IDK Why i want an EBC it was just more apealing I tune the well, but I don't want to lean out so i figured just to leave the Fuel and Air alone untill I got a Tune. Ahh I guess I get to go and have fun tunning the controler.
v8<turbo4
16
Sep 24, 2007 06:09 AM
David Buschur
69
Jun 30, 2007 09:47 AM
David Buschur
225
Jun 25, 2007 07:54 AM
David Buschur
AEM EMS
15
Jan 11, 2006 08:00 AM
PeakBoost
34
Nov 4, 2005 05:56 AM
