p0300 code on 03 evo
Old Feb 20, 2007 | 10:11 AM
  #31
jqturbo's Avatar
Originally Posted by Gsxtremedsm
So I have an 03 with 47k miles... I have had a reflash and I still get the code. For me I get a constant misfire every five seconds...
Literally every five seconds on the highway. Sometimes I can accelerate slowly/keep the same speed and it won't studder.
So if I get a creader is it just going to clear the code? Or will it stop the constant, horrible, (makes me want to blow up the car) studder?
Any info would be great.
BTW someone said earlier that Mitsu will rebuild a tranny. Is this for the 60k warranty? So this would include me correct. Or is this a complete recall and includes everyone with the problem.
Same thing was happening with me. I didn't want to drive the car on the hwy ever! Every 5 sec it would vibrate/misfire.
What plugs and gapping are you running? I had Iridiums when I had the issue, but guess they got messed up, cause whatever gapping I tried to set, it still continued. I probably messed up the electrode since I heard they are sensative. Finally switched to the basic BR8ES (colder, yes), with a .022 gapping and don't have the issue anymore. Try it. You probably can even try the BPR8ES or BPR7ES gapped at about .024. See what happens then and keep us informed.
Old Mar 8, 2007 | 10:17 PM
  #32
EvoBig16G's Avatar
Originally Posted by Jamie@WORKS
Mitsubishi released a TSB mid-2006 that addressed a worn input shaft on the transmission as being the root cause of the P0300. The first step is to get their latest P0300 reflash. If the car is still triggering the code and meeting a few other criteria (i.e. full operating temp while cruising at freeway speeds), they're supposed to rebuild the transmission and replace the input shaft with an updated part along with the input half of 5th gear.
If i ever decide to rebuild my tranny with Shepard Racing or TRE do i have to tell them that I have an 03 Evo with a P0300 code problem? or do they automatically replace the input shaft with an updated part along with the input half of 5th gear as part of their tranny rebuild?
Old Mar 8, 2007 | 10:32 PM
  #33
Gsxtremedsm's Avatar
Well I have an update, I purchased a creader. It does help but doesn't cure it. Instead of having a misfire/studder 100+ times on the interstate in an hour, it will do it once. I clear the code, and it stops. However it will still misfire/throw the code about 4 times in an hour on the interstate.
I also noticed now that my car will throw the code/studder in third and fourth gear if I am getting off the interstate after an hour or so.
It won't do it around town, or 30 minutes or less on the interstate.
I changed my plugs recently. I already had bpr7es in which is what I kept. I gapped them at .26
I am going to try the colder plug 8es and gap it a little smaller.
Will this hurt my performance at all? Should I try the 7es at a smaller gap ex.. .22 or so?
Any thoughts. BTW my car just hit 49k, but has been doing this since 33k. I know my warranty is up but I am supposed to have some kind of 60k warranty right?
Will any dealership consider honoring a warranty and replace the input shaft/rebuild my tranny? Otherwise how much is it for a shep rebuild?
Old Apr 16, 2007 | 04:43 PM
  #34
Ricky Bobby's Avatar
Any updates on your situation Gsxtremedsm? I have a similar, if not the same problem. Here are a couple other threads with the same kind of issues:
https://www.evolutionm.net/forums/sh...d.php?t=256581
https://www.evolutionm.net/forums/sh...d.php?t=261958
Anyone have a solution.... or rather, anyone actually experienced this and corrected the problem? ...or know of anyone that corrected the problem?
Old Apr 27, 2007 | 10:45 PM
  #35
evovin's Avatar
it is the coil pack! i tried changing wires, plugs and it still misfiring till i change the coil pack!
Old Apr 27, 2007 | 11:20 PM
  #36
joosdawg's Avatar
+1 on the coilpack
Old Apr 28, 2007 | 06:16 AM
  #37
hawaiian_evo's Avatar
i recently got this code after my hks 280s went in.
i think because im untunned and the idle is so lumpy the code trips
Old Apr 28, 2007 | 06:29 AM
  #38
nothere's Avatar
by coil pack, are you referring to the stock coil caps?
Old Apr 28, 2007 | 09:05 PM
  #39
evovin's Avatar
yup! replace it or do a test first using analog meter then from there you will know if its your coil pack or your wires!
cognizio
Outlander Sport
May 28, 2024 06:38 PM
DJErickG
Feb 11, 2015 05:57 PM
ryanholder24
Sep 20, 2011 02:57 PM
b00st3d.
Jun 20, 2010 08:49 AM
Poondoggs
Nov 6, 2009 04:15 AM
