Cam Install tips
Old Jan 15, 2007 | 12:53 AM
dxbevo9's Avatar
Cam Install tips
hey guys...i am working on installing the cams... just need a little heads up.. i have never seen or done MIVEC cams before...
anything different from the evo VIIIs?? evomoto's How-to is for non mivecs...is there anything i should look for other than whats in the How To?
and there was once a link on how to bleed the lifters with pics...i stumbled upon it once and couldnot find it again...if anyone has it please post the link here...thanks guys
Old Jan 15, 2007 | 01:04 AM
dxbevo9's Avatar
ok found the link to bleeding the lifters...
http://www.joe250.com/cars/evo/camshaftinstall.htm
any heads up on the MIVEC?
Old Jan 15, 2007 | 06:18 AM
dxbevo9's Avatar
Sweet....20 veiws no input...!!
Al....Buschur...Greg.....anyone??
Old Jan 15, 2007 | 09:55 AM
ghoonk's Avatar
Wouldn't recommend installing the cams yourself. Get Wissam to do it. He may be expensive, but he's good. I've seen his work. You'll also need some money for a custom tune. No point doing cams and getting a mail-in reflash.
Old Jan 15, 2007 | 04:09 PM
GregGSC's Avatar
Pointers...
The little Cap on the mivec gear is made of aluminum and requires 32 N-M can be broken very easily it uses a 14mm Allen. Make sure you buy one that will work with your tq wrench.
you can either stuff a rag in under the mivec gear when you remove the aluminum cap it will spill some oil out of it. Keep that off the timing belt. you can zip tie the belt to the gear and use the timing belt tensioner tool just like on an 8. the 9 mivec doesn’t require any bleeding. and as far as the lifters go, not really necessary unless you have the car sitting for days or weeks.
One thing to watch out for if you remove the timing belt completely. Watch the Oil Pump gear and make sure that it doesn’t move. There is a balance shaft behind it and that can actually go 360 degrees out, and all the marks will line up, but it will be out. it will cause the motor to vibrate badly at about 4k rpms plus.
Old Jan 17, 2007 | 04:12 PM
dxbevo9's Avatar
Originally Posted by GregGSC
Pointers...
thanks for the pointers greg... will let you know how it goes
Old Jan 17, 2007 | 04:17 PM
dxbevo9's Avatar
dude...you are just assuming things...i dont know who told you that i am going to get a mail in...i have installed all the parts on my car by myself except for the clutch...whats the fun in owning an evo if you are gonna pay someone to mod it for you.??
i have saved in upwards of 9000aed ($2700) on labor just by installing parts myself...atleast when i do it myself i am confident that its done with care and everything went back to where it belongs..
ghoonk we both know how workshops are here in dubai...lets put it this way...
and oh...you baby your car like no other..you should take it out and race it like it was built for
holla at me if you wanna go for a drive sometime
Old Jan 17, 2007 | 05:17 PM
ntwaddel's Avatar
DIY
shadow_X
May 4, 2013 09:49 PM
evo_q8
Sep 9, 2012 09:56 AM
Lukelis
Dec 21, 2011 07:00 AM
fvaldes
Sep 7, 2011 07:28 PM
impreza2darksyd
Aug 16, 2007 03:35 PM
