2.3l stroker kit
Old Feb 11, 2007 | 07:20 PM
kyle424's Avatar
2.3l stroker kit
im getting a 2.3l stroker kit where did you guys go to get you engine re-bored?
Old Feb 11, 2007 | 07:22 PM
riceball777's Avatar
more ppl will do a .5mm over bore (85.5mm) so they know the cilinders will be perfectly round and not over shaped
Old Feb 11, 2007 | 07:29 PM
kyle424's Avatar
where did you get yours done?
Old Feb 11, 2007 | 07:31 PM
Exciting News's Avatar
You're getting just the rotating assembly and not a shortblock? If so, I'm sure there's a local machine shop in your area that could do the boring after you give them your block. Let your fingers do the walking.
Old Feb 11, 2007 | 07:33 PM
kyle424's Avatar
what whould the advantages of getting a shortblock be than just getting it re-bored
Old Feb 11, 2007 | 07:39 PM
well i'm on the stock motor on my evo
but there are a lot of machine shiops in so cal
for my honda i go to rs machines, golden eagle or bensons
Old Feb 11, 2007 | 08:04 PM
kyle424's Avatar
what would the advantages of getting a shortblock be than just getting it re-bored
Old Feb 11, 2007 | 08:26 PM
CO_VR4's Avatar
The main advantage of getting a shortblock is that you have the entire bottom end properly built by a shop that knows 4g63s, do rebuilds on them regularly, and has the equipment to do it right (at least if you're dealing with most of the well known shops). The block is bored with a deck plate, etc. etc.
If you have a very good shop locally, you can save some shipping costs for the block and the core and have it done where you can see it progress. However, most local shops will not have a deck plate for a 4g63, or other similar tools that make the job come out better.
Old Feb 12, 2007 | 12:25 AM
Frenchy4g63's Avatar
+1
It's always better to get a stroker or any built motor for that matter as a complete short block. If it's done by a good shop, it should be balanced and the tolerances should be within spec.
Get the short block if possible. Or do a lot of research on the shop you choose to have assemble it.
Good luck with the build
Old Feb 12, 2007 | 07:41 AM
Jackson Machine's Avatar
Kyle we could help 'ya out. Where are you located? We ship engines all the time and get pretty good rates with the freight company. We do all of our work in house so you know it'll be done right. We could do just block prep or an assembled shortblock. Give us a call at 410-89-3269, make sure you mention you're from EvoM.
BoostLover99
Dec 1, 2008 01:08 AM
Evasive EVO
Oct 6, 2008 02:59 PM
richysevo8
100
Mar 2, 2008 08:19 AM
Evo9Kid
Jul 16, 2007 07:44 AM
NocturnalEVO
May 18, 2005 11:20 PM
