Pros/Cons of 100%meth or 50/50 mix
I have, and I'm not entirely in agreement with them (not the AFR vs power discussion anyway).
I'll offer this sound bit of logic:
IF his assertion that his cylinder wall finish was compromised purely as a result of methanol injection is correct, than a host of forum members (including myself) should observe the very same thing when we pop our heads (which I'll be doing before long). Has anyone else reported the same?
IF his assertion is incorrect, then we won't witness the same thing, and best evidence suggests that it was due to something else particular to his setup (elements of which are apparently atypical).
My point is simply that right or wrong, one example hardly constitutes a statistically valid sample, especially when no other (?) similar reports have surfaced.
I am switching all three of my cars to solenoid control of some sort.
The video shows very clearly the overun of meth. I think it is this alone that causes cylinder wash. A/F goes very rich during coastdown when it should be very lean. I just removed head on a fresh engine with only 5000 miles on it. Always run with 10g jet from day one. I am seeing the same thing. Cylinder wear is rapid. I wish it weren't true.
Check valves are only gonna be around 1 bar(15psi) . The other 12 bar(200psi) of pressure still bleeds off. The check valve is to prevent engine vacuum from sucking the line dry. It doesn't help with overrun issue.
Shurflo recommands using a checkvalve no greater than 2 psig.
Coolingmist uses a 22 psig CV - not a good idea for a progressive variable pressure/flow system as it further limits the already limited dynamic range of a pwm pump speed system.
I use one of these, cheap and effective
http://www.ecivalves.com/specs/SpecsS2400.htm
Ted B / others -- Anymore insight into cylinder washing? 94AWD's findings are very concerning to me and I want to see if others are experiencing the same thing.
Based upon what I have read, I think I will go the alk (either 50% water / 50% denatured alk. or 100% denatured alk.) primarily because of availability (lowes, home depot, etc.).
Not with a system that has proper overrun shutoffs, like the Aquamist.
Vigman
Jan 20, 2011 11:55 AM
Mad_SB
91
Dec 30, 2007 04:08 PM
gunzo
50
Oct 30, 2006 03:31 PM
