Paculiar noise at decel??
Old Feb 19, 2007 | 11:36 AM
MyEvoRocksUrv8's Avatar
I just had a new clutch and flywheel (both ACT) installed on my 03 GSR and ever since then it's been making a rumbling noise at decel no matter if it's in gear or not. All fluids have been changed when the install was done, and I only have 13,000 miles on it. I don't think it could already be my transfer case going out could it? I was hoping it is just drive train slack. What do you guys think??
Thanks for all help
Old Feb 19, 2007 | 01:43 PM
BMan's Avatar
It may be your transfer case. If the wrong fluid goes in, it will eat the ring/pinion quickly.
I had a Mitsu dealer change the oils and they put the wrong stuff in and it was gone in 1000 miles.
Old Feb 19, 2007 | 02:14 PM
well all fluids were changed with Redline, and they used oem for the transfer case. As far as I know those are correct fluids to use. It started making the noise immediatly after the install though. The only way i can really describe it is it sounds like an electric can opener opening a can, but it's not extremely loud. BTW its only when i decel, so I thought it MIGHT be because it revs down a lot faster since I have a lightened flywheel. Do you think it could be anything other than my transfer case?
Thanks for the reply.
Old Feb 19, 2007 | 03:49 PM
barneyb's Avatar
This is exactly the noise my car has made since day one and after 35000 miles it doesn't seem to be getting any worse. I use OEM fluids in both the tranny and transfer.
I have a copy of Microsoft's Rally Car game (don't remember the exact title) which I play occasionally and Of Course I drive the Mitsu. Well, the sound track has the competition car in the game making the same sound only much louder. So, I'd say you have the privilege of experiencing the true rally car sound.
Old Feb 19, 2007 | 04:26 PM
SolidAutoEvo's Avatar
On decel in gear, and when you push in the clutch does the noise go away?
Old Feb 19, 2007 | 07:24 PM
hk2ronin's Avatar
Its just normal noise on the 03's. Depends on your clutch\flywheel setup. My friend has act with stock flywheel and his stock noise lessened after install. Another friend of mine with the exedy stage one/stock flywheel noise got louder.
Old Feb 19, 2007 | 07:49 PM
yeah, the noise goes away once I push in the clutch, so I thought it might be that the new clutch wasn't installed properly, but after reading all this I'm sure it was. I'm so glad to hear it's probably not my TC, that would have ruined a lot of plans I had for it if I had to replace the transfer case. Thanks everyone for your help!
Old Feb 19, 2007 | 07:52 PM
Apex Racer's Avatar
I have an 03 with the act street and fidanza light flywheel and it makes the same noise. It seems to be a normal accurance.
Old Feb 19, 2007 | 07:58 PM
SiCKlEyWiKeD's Avatar
A lightened flywheel will be nosier and your revs will drop faster cuz less weight = less inertia
Old Feb 22, 2007 | 07:36 PM
so it's allright to let off the gas and just hear the noise, or is that harmful? or should i push the clutch in immediatly after I let off the gas? is there any way of preventing the noise? also, does anyone know why it would only be that it makes the noise in 4th gear?
Old Feb 22, 2007 | 10:28 PM
anyone??
Dross99_si
13
Sep 16, 2016 10:57 PM
xXANCHORMONXx
Mar 5, 2012 11:19 AM
dRifT iT
28
Jun 13, 2010 11:38 AM
Vapor
10
Feb 19, 2007 11:08 AM
sir lurks alot
10
May 9, 2005 09:22 AM
