The Official MBC Install Picture Thread
Old Feb 26, 2007 | 12:45 PM
  #31
03evopa's Avatar
How high can you really turn up the boost with a controller. They probably only let you go so far right?
Old Feb 26, 2007 | 02:47 PM
  #32
Lancerguy'03's Avatar
with the one from RRE (dejion tool?) i could see it going past 2.0bar no problem....
Old Feb 26, 2007 | 02:55 PM
  #33
KevinD's Avatar
uhhh, really want to know? tell you how, remove the vacuum line from the wastegate actuator and floor it in 4th gear you'll know really quickly.
essentially, a MBC can be adjusted to hold any amount of boost. you might need stiffer internal springs but thats easy to change out.
Old Feb 26, 2007 | 08:40 PM
  #34
03evopa's Avatar
well Its not like I want to run alot of boost but I see alot of people running up to 24psi. Is that safe for the stock turbo? A flash would be a good thing for that right.
Old Feb 27, 2007 | 04:21 AM
  #35
kmcconn9's Avatar
24psi is fine on the stock turbo. Its your state of tune and the type of fuel that you are running. Generally you dont run more than 21lbs on the 93 pump. Now with race gas or alcohol/methanol....then you can start to turn the boost up safley.
Also Hallman has two different springs. One for low boost applications, and one for high boost.
Old Feb 28, 2007 | 05:07 AM
  #36
kmcconn9's Avatar
More pictures!
Old Feb 28, 2007 | 08:39 AM
  #37
occultworks's Avatar
Old Feb 28, 2007 | 09:11 AM
  #38
now ive heard 22.5psi is a good number with someone who has TBE and a good tune on 93oct. @ 24psi ur starting to push the limits of ur turbo and blowing hot air with is not good....
Old Feb 28, 2007 | 10:20 AM
  #39
kmcconn9's Avatar
/\ um, no. There are many people running more than 24lbs on the stock turbo....you recieved bad information my friend...
Lets keep this thread for MBC picture installs and not how much boost can be run on the stock turbo.....
Thanks!
Old Dec 10, 2010 | 09:12 AM
  #40
dastallion951's Avatar
to put in perspective i ran 24 psi peak holdin about 20-21 at redline with dejon tool mbc on 91 octane...its all in the tune...my tuner knows what hes doin...not to say yours doesnt...
btw heres my pic:
svt_lightning01
Mar 31, 2011 01:08 PM
Aux.
40
Aug 23, 2008 07:22 AM
alby988
May 20, 2007 08:25 PM
Aux.
Dec 21, 2005 08:45 AM
Obsoleteasian
Apr 12, 2004 11:37 PM
