ECU Wiring Harness "Extension" Update
Old Jul 8, 2003 | 06:41 PM
  #91
Z1 Performance's Avatar
Actually CN4 is the Field part number......I wish we had received even more in this first batch, but don't sweat it guys..should have more at the end of next week, first part of the week after!
Old Jul 8, 2003 | 06:53 PM
  #92
YellwTyper's Avatar
How much more different are the Evo 8 ECU's from the Evo7 ecu? Im still a little confused on how this actually works. So what you guys are doing is getting the ODBII-OBDI converter harness, or am I talking about something completely different? Do you know if anyone is making a harness specifically meant for the Emanage setup, SAFC, and etc?
Old Jul 8, 2003 | 11:56 PM
  #93
Coolguy949's Avatar
This harness they are taking about is basically an extension cord for your ECU wires. It has the same fittings as the ECU. Its purpose is so you can splice all your connections for mods on it without needing to cut up the stock wiring. If you ever wanted to convert your car back to stock you would just take out the extension and remove all your electronics without needing to un-splice anything.
Old Jul 10, 2003 | 08:34 AM
  #94
cotte001's Avatar
harness extension
So, do I need this ECU harness extension for an HKS turbo timer type-0 [in addition to the HKS turbo timer harness (MT-6)] in order to avoid splicing into the stock wires?
Old Jul 10, 2003 | 08:49 AM
  #95
instigator's Avatar
Re: harness extension
The MT-6 Harness is so you don't have to splice the ignition wires. The turbo timer will only splice to the ECU if it need a speed sensor or something like the Greddy FATT. I connected my Greddy TT with the harness without splicing anything and I will wait to connect the Speed sensor wire when my new ECU Extension harness gets here tomorrow.
Old Dec 7, 2003 | 11:19 PM
  #96
Thoe99's Avatar
Are these harness still for sale, and are they still $100+?
Kris@MVP
10
Feb 10, 2007 02:03 PM
xLaNcErEvOx
Gruppe-S Engineering - California
37
Jul 29, 2005 10:52 PM
ThEHiTMaN
Jul 3, 2005 07:05 PM
LancerShop.com
May 19, 2004 09:52 AM
MaxBoost
23
Jun 9, 2003 12:48 AM
