real intercooler test on the way
Old Aug 29, 2007 | 02:51 PM
  #376
Ralph's Avatar
Originally Posted by ifarted2
We just check the data logs. We are heading to BOTI this friday i will make a note to get some better feedback for you
But 20deg is pretty darn good with car making close to 1000whp. But the log before was from the burnout box to the end of the 1/4mile
Off topic from the thread.... But are you heading out to Bakersfield for the BOTI finals? End of October?
Please say yes, haha
Old Aug 29, 2007 | 07:34 PM
  #377
Paul Nelson's Avatar
Nah just BOTI in Las Vegas Sept 16th
Old Sep 13, 2007 | 01:43 PM
  #378
Kc2Buk's Avatar
How about an Up-Date?
It's been what like 6 months?
Old Sep 13, 2007 | 11:14 PM
  #379
APEX1's Avatar
$132 shipped at xspower.com. Works just fine for me.
Old Sep 20, 2007 | 08:23 PM
  #380
nightwalker's Avatar
There probably will never be an update because of the retarded remarks made at the OP.
What did Zeus say? .......yeah...............
Old Sep 23, 2007 | 02:14 AM
  #381
discopotato03's Avatar
From post 328 , why wouldn't he test the same intercooler cores with different end tanks ? The core itself is not a charge air cooler until it has tanks to feed and collect from the cores tubes and how the core is fed is critical if you want it to work properly . I see heaps of intercoolers from all round the world and yet many are a polished piece of junk .
To be effective a charge air cooler has to pass the air necessary to feed the engine without significant resistance to airflow , this is more important initially than the air temp reduction because even if the post IC air temp was at ambient you won't easily get the forced air into the inlet manifold so manifold pressure falls off . Your turbo won't like it much , turbine not turning as fast as it would like so slip losses/exhaust restriction etc etc .
Secondly , to reject heat the air must slow down to the point where its exposed to the inner surfaces of the tubes so that heat transfer can take place . It has to have some turbulence so as to avoid the barrier flow problem hence the "turbulators" in the tubes - radiators and oil coolers have them as well .
The most effective charge air coolers I've seen have tanks top and bottom rather than at the sides (when they are wider than they are tall) so they have more if shorter tubes . All else being equal they have less resistance to airflow through the core because it now has a greater number of the same sized tubes . So you now get the lower velocity through each tube (more time to reject heat) and less pressure drop (flow resistance) overall .
I have to assume that collecting the air from the low pressure drop core is easier because the gas speed is lower out of the tubes so easy to make change direction without additional pressure drop .
I know of at least one firm over there doing such an intercooler but can't remember which make of car it's for - pretty sure its a Mitsy or a Subaru . I did see one built here - must be 7-8 yrs ago for a drag Lancer GSR (built to ~ Evo 3 spec) and intercooler wise it worked well .
My two kangaroo cents worth , A .
Old Oct 30, 2007 | 08:44 PM
  #382
EvoDan2004's Avatar
bump for updates????
Old Oct 31, 2007 | 09:54 PM
  #383
evovin's Avatar
bump too
Old Nov 8, 2007 | 10:53 PM
  #384
_ceteuro's Avatar
what are the results?
Old Nov 12, 2007 | 05:21 PM
  #385
Bster13's Avatar
bump
Old Nov 12, 2007 | 09:31 PM
  #386
_ceteuro's Avatar
Alright! it is time to pull the BS Flag. This was the biggest build up ever and the worst let off ever. "It's like playing with yourself and right when you are about to release, you stop." WTF!!!!
Old Nov 12, 2007 | 09:39 PM
  #387
JDMCT9MR's Avatar
I just got the ETS 3" and couldn't be happier!
Old Nov 13, 2007 | 05:02 AM
  #388
chmodlf's Avatar
Move on guys. This was a great idea but this thread is dead...
Old Nov 19, 2007 | 04:09 PM
  #389
evovin's Avatar
what about this fmic?>>>http://machevo.com/diyinco.html
This is a good website for evo parts I dont think they will carry Sh** stuff!.....
Old Nov 19, 2007 | 04:23 PM
  #390
denny424's Avatar
I got my AMS FMIC and its the best FMIC on the market and thats the GOD honest truth! But for real its a great intercooler!
