Gates Racing Timing Belt
Old Mar 4, 2007 | 11:29 AM
ex-honda's Avatar
I was searching around for a new timing belt for my Evo. I saw Gates racing and heard alot of good things about them. But when I went to their website to look up the belt, it says "interference engine application." Has anyone run into any problem with them and what interference are they talking about?
thanks
Old Mar 4, 2007 | 11:44 AM
wrcwannabe's Avatar
Interference fit engine is an engine that the valves can contact the pistons if the timing belt or chain breaks . With one cylinder or more with the valves fully open and the piston coming up.
Non inteference engines dont have clearance problems when the piston comes up with the valves fully open.
Milburn
Old Mar 4, 2007 | 11:58 AM
EVOlutionary's Avatar
An example of an interference engine is the 4G63 (EVO). If your timing belt breaks you are screwed. Broken valves, broken pistons, destroyed head.
An example of a non-interference engine is the 1JZ/2JZ (Supra). If your timing belt breaks, you just replace it and keep on going. No internal damage should occur.
EVOlutionary
VanScoter
Jul 11, 2021 09:29 AM
CamaroDave
17
Jul 3, 2012 07:59 PM
LC@GSC
35
Aug 24, 2007 06:30 AM
white05evoVIII
Jan 16, 2006 06:24 PM
captain150
Jun 9, 2005 08:59 PM
