afr's
Old Mar 17, 2007 | 08:53 AM
superflyevo's Avatar
afr's
just installed my wide band and went out and tested it, when i do a 3'rd gear roll
it reads 11.3 when i shif into the next gear it goes to 10.8 ish.
does this sound right ? i never have had a wide band, new to the hole thing. i have a dynoflash mail in flash with numerous other mods
thanks for your time fellas
Old Mar 17, 2007 | 08:55 AM
SlowCar's Avatar
you got alky?
Old Mar 17, 2007 | 09:50 AM
Originally Posted by SlowCar
you got alky?
no
Old Mar 17, 2007 | 10:05 AM
hopper's Avatar
Do you have a blow off valve thats vented to the atmosphere??
Old Mar 17, 2007 | 01:13 PM
nope
forge recirculated
Old Mar 17, 2007 | 03:13 PM
hopper's Avatar
Just a rich tune I guess, Mail in flashes are notoriously conservative. Add more boost and lean it out
Old Mar 17, 2007 | 03:52 PM
i thought the higher the # the leaner it is
i thought 11.5 is a good for pump gas, was expecting more of a 10.5 afr
Old Mar 17, 2007 | 07:23 PM
hopper's Avatar
Your right, The higher number the more lean it is on a Lamba gauge, 11.3 is where it should be. maybe a little leaner at peak torque. But your safe. its a little rich but its fat and happy.
Old Mar 18, 2007 | 01:14 AM
yikez's Avatar
i got the same readings as well
jestr flash
what's your idle at?
Old Mar 18, 2007 | 08:09 AM
jestr flash
1k rpm i think, mabye a lil over
so what is a good afr on pump gas
whats a good afr on race gas
Old Mar 18, 2007 | 08:15 AM
feautoevo's Avatar
I need a wideband
Old Mar 18, 2007 | 09:48 AM
hopper's Avatar
Depending on ignition timing and boost anywhere richer than 12.0 is usually safe on pump gas. Race gas is really dependant on what octane race fuel and the tuner that tunes it
Old Mar 18, 2007 | 02:57 PM
well im on stock ecu, i have axcess to c16 how high can i safely turn the boost upto
Old Mar 18, 2007 | 08:05 PM
hopper's Avatar
If it was my car I would turn it up to 25-26 Psi on c16.
Old Mar 18, 2007 | 08:43 PM
Nad1370's Avatar
Perfectly normal.
As you go to higher gears, the load increases and falls into a richer scale.
This is what you want since it will take you longer to pull in that gear to the next and you'll want a richer afr's than a leaner one so you won't detonate.
UnArmed
Apr 3, 2014 10:39 AM
tweakdsm
Mar 31, 2010 03:06 PM
05lanceralliart
Apr 2, 2009 07:01 PM
paintballproam
Apr 23, 2008 09:13 PM
KOEvo
Nov 27, 2005 07:31 AM
