odd trouble codes need help
Old Mar 19, 2007 | 10:54 PM
evilevo2006's Avatar
ok i keep getting
PO335B which is crankshaft position sensor A A circuit malfuntion
PO340 which is crankshaft position sensor A circuit BL
car runs fine. as soon as i clear the code BAM the lite is back on. these to codes keep poping up. any idea's????
Old Mar 20, 2007 | 07:46 AM
93turbomax's Avatar
Do u have any mods?
Old Mar 20, 2007 | 07:52 AM
4TUN8's Avatar
https://www.evolutionm.net/forums/sh...ighlight=PO340
did you just have cams installed?
yea. all bolt on's and cams. just got done doing a timing belt.
Old Mar 20, 2007 | 07:55 AM
yes 4tun8 i did.
Old Mar 20, 2007 | 07:56 AM
4TUN8's Avatar
I have a feeling your timing is off. Or you messed something up during the install....did you do it all yourself? Or did you have a shop do it?
edit: btw next time post this type of thing in Engine Turbo Drivetrain section, it will make it easier to search for, and will be in the correct section.
Old Mar 20, 2007 | 08:04 AM
ok sorry for the wrong post spot.
i had a shop look at the car. i brought it there not running and they got it running. they fixed my timing and a few other things. then the code just keep poping. right after i clear it and the light go's off not even a second later the lite come's back on. car run's fine. but when im driving coming to a stop is where it wants to stall out. if i tap the gas and try to help keep it around 1k rpm it will level its self out and not stall. the shop said they check'd everything and it was all conected. now im wondering whats going on here. lol
Old Mar 20, 2007 | 08:27 AM
how hard is it to check the timing myself?
would someone mind guiding me thru it?
Old Mar 20, 2007 | 04:10 PM
anyone?
Old Mar 20, 2007 | 04:28 PM
4TUN8's Avatar
search for it bro, I was hinting, I don't feel like digging for you again =) Maybe I'll get bored and search for it for you later.
Old Mar 20, 2007 | 05:03 PM
Speedlimit's Avatar
Admin Emeritus
I moved over to Engine/Turbo/Drivetrain.
Old Mar 21, 2007 | 08:56 PM
ok well im not getting any help or any luck anywhere. i did search. i found nothing that helpd. my sensors are not wet. there on right. nothing makes sence. i dont know what else to do.
Chabada15
38
Oct 25, 2014 12:18 PM
Can Of Rockstar
Aug 9, 2011 07:40 AM
Evo818
11
Aug 27, 2007 07:12 PM
SLVROZ_03
Lancer Troubleshooting
13
Jul 28, 2007 11:35 AM
EdT
Lancer Engine Tech
17
Jul 23, 2007 06:07 PM
