hallman mbc problem
Old Mar 20, 2007 | 05:31 PM
06 SLOW EVO's Avatar
hallman mbc problem
i just had a shop put on this mbc and when i drove it out it was only going to 10lbs. so i get out start to turn it and i kept testing it to see how much i would have to turn it to get it back to the stock setting, so i kept turning it and when it hit the end to where i couldnt turn it anymore, it would go to about 19 and drop down to about 16 at redline. i am really confused becuase i thought it was supposed to go at least over 20. please help
Thanks
Old Mar 20, 2007 | 05:35 PM
MYEVOVIII's Avatar
How did you hook it up?
Old Mar 20, 2007 | 05:37 PM
wat do you mean, where did i put it
cij911's Avatar
You have the 'soft' spring installed...replace with the 'stiffer' spring...
ya im gonna replace the spring tommorrow. should that fix the problem?
Old Mar 20, 2007 | 05:38 PM
cij911's Avatar
Per my earlier post....YES!!!!!!!!!!!!!!!! JUST MAKE SURE YOU TURN THE DIAL ALL THE WAY BACK!!!!!!!!!!!!
Old Mar 20, 2007 | 05:39 PM
MYEVOVIII's Avatar
Vacumn lines how did you install it? Not location of where it's mounted.
ok ill make sure to do that
Thanks
Old Mar 20, 2007 | 07:40 PM
spln*up's Avatar
check to see if they left the resistor pill. if not the check the lines, the bottom part goes to pressure and top one goes to wastegate.
Old Mar 20, 2007 | 07:44 PM
AWDTurbo4's Avatar
another reason why u should install parts yourself...or let an EVO EXPERT do it......but not just "a shop"
Old Mar 20, 2007 | 07:45 PM
dubbleugly01's Avatar
need to know more about vacuum line routing.....
Is the reference coming off the turbo, or off the manifold? Obviously, one vacuum line has to go to the wastegate, but is the other vacuum line being supplied from the turbo outlet or manifold?
But I agree with the previous posts, you probably also have the soft spring installed, but even with the soft spring, you should be seeing more boost pressure than you are, more like 22#'s peak, tapering to 18#'s or so.
evillancer06
Oct 5, 2016 12:15 AM
Smurf Rocket
Aug 6, 2007 06:41 PM
Profoxcg
24
Mar 13, 2007 07:39 AM
EVIL_EVO_VIII
20
Mar 10, 2006 09:50 PM
QuickEvo
15
Oct 26, 2005 03:38 PM
