Open air filter in engine bay?
Old Mar 25, 2007 | 06:01 PM
jrsimon27's Avatar
ive been searching for an open air filter(no k&n,and get a tune)
know i have a question: are this open air filters affected with high tempetures of the engine bay?
i ask cause i had a bmw m3 and modified the air intake bought it from dinan and this filter was located in the lower part of the front bumper with a heat shield on it this was to eliminate heat from the engine bay being sucked into the filter.
iam certain this open aiffilters in the evo are affected by heat so why vendors dont do anything regarding this issue?
thanks for any comments
Old Mar 25, 2007 | 06:10 PM
Kings Fan's Avatar
Once the car gets going, cool air will be blow across the engine bay and the filter. You can make a heat shield, but it has to isolate the filter from any open access to the hot air. Search for the Apex induction box and you'll see an example
Old Mar 25, 2007 | 06:14 PM
jrsimon27's Avatar
yep ive seen this box
but ive been logging air temp in a friends evo who has an open air filter and his air temp are higher then my car which i have the stock airbox.
we do 1/4mile races and his car is highly affected to this intake temp
Old Mar 25, 2007 | 06:25 PM
yas06IX's Avatar
I always heard that with the evo your best bet is stick with the stock airbox or something similar with a good drop-in filter. I like the sound of the car with an intake or open filter but if you are looking for max performance then stick with a setup that eliminates hot air from under the hood either way you need a tune to get the most out of it and not run even richer
Old Mar 25, 2007 | 06:26 PM
YELOEVOVIII's Avatar
ya i have the blitz open top air filter and screen with the stock box works great.
Old Mar 25, 2007 | 06:35 PM
Jer.k's Avatar
I was bored yesterday so I bent up chromed sheet metal for my ARC box top filter and it came out pretty good I think
Old Mar 25, 2007 | 06:43 PM
4G63's Avatar
Wow...that looks pretty good!! Do you think that cover will become a heatsink when it gets hot?
Old Mar 25, 2007 | 06:51 PM
jrsimon27's Avatar
thats a nice solution
elpoole
Lancer Engine Tech
20
May 8, 2008 11:45 AM
dpacific
Apr 16, 2008 04:32 PM
_EVOlved_
Aug 18, 2006 04:36 PM
clckwrkorang777
Lancer Engine Tech
49
Jan 21, 2005 10:35 AM
J8dailo
Oct 14, 2004 11:22 PM
