06 evo9 Transmission Drain Bolt Size? bigger than 21mm
Hey guys, im trying to change my tranny fluid and im not sure what size the drain bolt is. Its hella bigger than my 21mm socket and before i bought a ton of em just to guess i wanted to see if anyone knew the exact size. Thanks!
Plus removing the fill plug will help the fluid train out of the tranny MUCH quicker. Just be sure to remove the fill plug all the way before you remove the drain plug. If you only loosen the fill plug then start to drain the tranny, when you remove the fill plug the rest of the way you'll get a sudden surge of tranny oil that will splash all over your drain pan.
SleepySamurai13
Apr 28, 2017 05:04 AM
LIL EVOL
Apr 3, 2007 10:32 AM
