2.5l - 10.25:1 compression - EVO IX motor pictures!
Probably he went with the TME due to the rule restrictions in his rally series. The TME is a fast spooling, Mitsu factory homologated turbo and with a 30mm intake restrictor a larger turbo isn´t gonna do much good anyway.
It's true but potentially misleading, as WRC cars use a small turbo that is only effective at generating relatively low rpm power. As such, WRC engines are designed specifically to deliver peak torque at modest speeds (e.g. 3500 rpm). With sufficient cam timing, 10:1 CR is practical because the effects of valve overlap are most evident at low engine speeds (bleeds off some of that high cylinder pressure), so the effective cylinder pressure is more like that of an engine with stock cams and CR. This is why engines with big cams and high compression ratio can tolerate more ignition advance at low rpm.
If we install a larger turbo on the car and shift the power to the right such that the effects of overlap are diminished, the higher compression ratio will become a limiting factor with pump fuel.
Just FYI
Thank you Ted for the insights, but my point was more octane versus boost. For instance the 15GK that Mitsu uses or the IHI's that Subaru use are designed with high pressure ratios and short lifespan's in mind. My point was more that a motor breathing through a restrictor actually has less available oxygen no matter what the boost is and therefore would have less fuel and less combustive energy. You can survive at 3psi air pressure if the atmosphere is 100% oxygen because of diffusion of oxygen atoms is the same as 21% at 14.7 (This is why NASA did it until the ill fated Apollo fire). But it still stand that 44psi of boost on a 10:1 motor and 104 octane fuel is being done. I do question the exact composition of the "control fuel" that the FIA allows however.
I dont think anyone disagrees that if we were using a GT35R on an unrestricted motor with 10.2CR we would have some severe issues. WRC motors dont tend to run radical cam profiles as they arent conducive to keeping that torque in a nice broad powerband they just let AVCS, MIVEC, or whatever the variable valve control system is being utilised. But they use them just as you pointed out to bleed off some compression and alter the dynamic compression ratio.
The question about why not a GT30R, in open class the rules are in fact open in most areas. But as we are talking about you want the turbo that keeps the power the highest (at least in Subaru as I havent seen the actual dynosheet and failed to ask ACP last time I saw him) between 3 and 5K. It stems more from cost to rebuild aspect, suitable engine match, availability, and the ability to last whilst working with antilag. Sorry I didnt mean to cloud the subject and be potentially misleading either.
JB
JB
Man I remember sbr from when I used to frequent dsmtuners. From building o.g. bullycars to building new style rally cars, you guy have come a long way. I remember back like 4 years ago when I and a whole bunch of friends ordered a whole bunch of stuff on a friends cc account right before christmas, you guys send us a christmas card signed by all the employees.. Don't mind my mumbling, I'm just reminessing. The moda looks really good.
Now using the 4g64 block out of the 2g n/t spyder dsm or out of the newer gen 3g elcipse? Do you get custom made longer rods and shorter pistons or do you punch out the block another .025 per bore and get O/S pistons made for it?
Thank you for remembering the good ole days - that rocks, look for us in a 1G TSI at the strip soon... lol... going to bring it back OLD SCHOOL.
Mike Huml
Slowboy
SBR INC
Mar 18, 2010 09:19 AM
SBR INC
53
Feb 9, 2009 01:41 PM
SBR INC
81
Jan 11, 2009 09:07 AM
SBR INC
Evo 'For Sale' Engine Internals and Drivetrain
16
Mar 30, 2007 06:01 AM
