Redline MT-90, where to use?
Old Apr 10, 2007 | 05:17 AM
joeMama's Avatar
^ Good Idea, The DiaQueen is the way to go....
Old Apr 10, 2007 | 05:41 AM
deanner's Avatar
Your 6spd only hold 2.3 qt so good luck putting in 3.
Old Apr 10, 2007 | 07:00 AM
Jeff_Jeske's Avatar
I'm giving the MTL/90 mix a try as my tranny will come out next month for a rebuild anyway. I normally run OEM fluids.
Old Apr 10, 2007 | 07:42 PM
bioman's Avatar
Originally Posted by iTune
for the 5 speed, i run strait MT-90.....but you have the 6speed, which really needs a 75w-85 oil....so.....run two qts of MT-90 and 1 qt of Redline MTL. That would be a great combo.
As for the TC and rear diff.....i run redline heavy shockproof in the TC and Redline 75W-90 in the rear diff. I am thinking about switching to heavy in both the TC and the Rear diff on my next change. We shall see..
CJ
This is the exact same combo I run in the Tranny. Great minds think alike.
Old Apr 17, 2007 | 10:05 AM
ace75's Avatar
has anyone here heard of or used lubrication engineers(LE) gear oil?
www.le-inc.com/DownloadResource?resourceID=61
Would this work in the EVO? Thanks.
Old Apr 26, 2007 | 10:49 AM
BBYBruno's Avatar
My Recipe included:
Motor: 5 quarts Redline Full Synthetic 10W30
Tranny: 3 quarts Redline Light Weight Shockproof
Rear Diff: 1 quart Redline Heavy Shockproof w/1.0 ounce of Redline LSD Additive
Transfer Case: 1 quart Redline Heavy Shockproof
The drivetrain feels really smooth and it eliminated a lot of decel noise and other misc drivetrain noise.
You hear of Redline horror stories because people use the wrong fluids in the wrong places. I've used Redline since the day I got my car with no problems. I had my transfer case replaced at 32k but not because of fluid issues.
AMS and Shep recommended Redline to me so that's what I use
Old Apr 26, 2007 | 10:55 AM
RazorLab's Avatar
Would love to see how you crammed 1qt in a tcase that holds .4-.5 qt.
Old Apr 26, 2007 | 10:58 AM
BBYBruno's Avatar
I crammed 0.58 qts in the transfer case
I said 1 qt because obviously you can only buy in quarts.
Old Oct 29, 2017 | 06:56 PM
jarod4's Avatar
So i live in Texas so it never gets THAT cold and im really tired of the notchy shifting. I just recently changed my transmission fluid to the redline cocktail and dont see that much improvement until i drive it for like an hour and then it gets smooth. I just recently bought the car and when i changed the transmission fluid it seemed as if it hadnt been changed in awhile cause there was quite a build up of the shavings on the plug.(no big metal chunks, just a lot of shavings) so i think im going to change it again and flush the system until most of the metal shavings are flushed out.
My question is, im using the redline cocktail mix right now 2MTL/1 MT90 but im considering changing it to 2 parts MT90 1 part MTL or going straight MT90 since im in texas to possibly eliminate the notchyness. Has anyone done this?
chaotichoax
Jun 8, 2020 06:10 AM
FlipSquad
Jul 24, 2017 03:21 PM
nor11384
Dec 30, 2016 08:18 AM
jimbo74
Apr 2, 2016 11:21 AM
nuggetinu1
Feb 15, 2016 03:16 PM
