evo8 20g/evo9 20g difference
Old Apr 11, 2007 | 02:57 PM
Duby's Avatar
I've done tons of searching and this may have been braught up a long long time ago . . . yea i'm probably going with a green but just for knowledge what is the difference between an evo 8 20g and evo9 20g on turbochargers.com's web site ? beside that you don't need the instal kit for the 9 onto an 8 . . . durrr
Old Apr 11, 2007 | 02:59 PM
KartaRailed's Avatar
That evo 8's and 9's have 16g's?
Old Apr 11, 2007 | 03:04 PM
Duby's Avatar
yea they come with 16Gs but i'm refering to the ones on turbochargers.com the 20Gs
I'm sure both are 6 blade but what else is different and is there amargin between the two in terms of power . . . it states 430vs450, evo 8-ev9 respectivly.
Old Apr 11, 2007 | 03:25 PM
Warrtalon's Avatar
The difference is one is made from an VIII turbo, and one is from a IX turbo. The VIII and IX turbos are different, and those differences are the same between the 20g-8 and 20g-9. There is absolutely no use for the 20g-8 nor the 6-blade 20g-9. The best turbos to use are the stock IX, 20G-9-5, and 20g-LT.
Old Apr 11, 2007 | 03:27 PM
Duby's Avatar
thanks, that's what I was waiting for.
Old Apr 11, 2007 | 03:28 PM
tvbf1's Avatar
From what I've heard is that the 20G-8 has boost surge problem, while the 20g-9 does not. I have no idea why, but it's on the buschur racing website.
Old Apr 11, 2007 | 05:58 PM
GHEvo8's Avatar
the 20g9lt makes amazing power where the others are
just tought i would add that in
Old Apr 12, 2007 | 04:56 PM
EVOlutionary's Avatar
Not true. 20G-9 can surge. EVOGreen/20G-LT can surge. Many people have it but don't talk about it and choose to call it "normal" or choose to live with it. Some vendors even say that ALL aftermarket turbos surge. It is possible, though, to NOT have it with the proper setup and tuning . . .
EVOlutionary
Old Apr 12, 2007 | 07:39 PM
EVO8904's Avatar
The 20G-8 is a POS, I swapped it out with a stock IX turbo the the IX turbo pulls harder and does not surge. If you are going to get a 20G get Buschurs new one. You don't want to get a turbo from turbochargers.com, forcedperformance.net makes the new 20G for Buschur and that is the way to go.......
Old Apr 12, 2007 | 08:41 PM
SuPeRNeT's Avatar
EVOlutionary
The 20G-LT has no surging issues, I put the car in 5th at 2500 rpms give it a WoT and it starts building boost..
Old Apr 12, 2007 | 09:14 PM
Sorry, I should have clarified - it is partial throttle surging that I am talking about. . .
Low RPM full throttle I have no problem with - I can make 30psi @2800 rpms in 5th gear with no surge. . .
Old Apr 12, 2007 | 09:29 PM
Warrtalon's Avatar
I wouldn't expect anything NOT to surge at part throttle when running high boost on a stiff BOV. That's not a "problem" per se, because the stock turbo does it just the same. The 20g-8 has a specific surging problem.
Old Apr 12, 2007 | 09:41 PM
You should! It is NOT normal. I'm sick of certain vendors telling us it's normal. This happens at low boost levels at partial throttle, so how high you spike your boost doesn't have anything to do with it. I could set my car to WG pressure (12psi) and it would do it.
I've driven an AMS 2.3/37R running high 30's for boost and it does not have any partial throttle surging at all . . .
EVOlutionary
Old Apr 13, 2007 | 06:28 AM
Bruzewski's Avatar
Both 20g surged so bad I could not autocross them. I was faster in my stock evo, because I could not "drive around" the surge.
Old Apr 13, 2007 | 06:37 AM
evo 8 ya's Avatar
^^^sweet avatar
drush08
Oct 22, 2008 02:47 AM
Evo8Emperor
11
Jul 24, 2008 04:56 PM
Gavin@TopLevelPerformance
20
Apr 5, 2008 05:55 PM
awddyno
90
Feb 6, 2007 05:01 PM
BADEVO
29
Mar 10, 2006 04:34 AM
