Little dilema... car wont idle :\
Old Apr 25, 2007 | 02:50 PM
  #31
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Alex change your oil. See if there is anything floating in it and report back. If there is some **** in there then its internal .... if there isnt its most likly something that fell off or came lose.
Old Apr 25, 2007 | 02:55 PM
  #32
bluebyu36's Avatar
you should do a leak down test that will tell you if u have a bad head gasket a compression test might not tell u.........but even if u did have abad haead gashet it will still idle fine what blow off valve do u have?
Old Apr 25, 2007 | 03:45 PM
  #33
vegasboy301's Avatar
changed the oil. nothing in it looked perfectly normal
Old Apr 25, 2007 | 03:53 PM
  #34
M3this's Avatar
hummm
Are you still runing SAFC on the car? or a flash ?
Old Apr 26, 2007 | 03:12 AM
  #35
hummm
safc, but didnt change any settings...
ive had a few people tell me it may be a censor?
i did a boost leak check today and everything went fine
Old Apr 26, 2007 | 08:36 AM
  #36
barneyb's Avatar
stepper motor? where is this located... IN the throttle body?
also just put blow off valve, fuel pump and oil to things i have changed.
Yup, in the throttle body. There's a hole in the throttle body that allows the entrance of idle air. The ECU controls the stepper motor running a pintal in or out of the hole to control the air flow and hence the idle speed. So, obviously, if this isn't working you will have idle problems.
Also, any air leak into the air circuit past the MAS will cause this problem. An air leak means there is more air actually getting to the engine than what the MAS is measuring. This causes the mixture to be lean.
Old Apr 26, 2007 | 03:51 PM
  #37
scanned the cell and got P0102 Mas or Volume air flow cuircuit low imput.. whats that
Old Apr 26, 2007 | 07:42 PM
  #38
blowoffsilver's Avatar
my friend is having this same problem, hope you figure it out and we will let you know if he figures it out too!
Old Feb 11, 2008 | 05:52 PM
  #39
Jameson_IXMR's Avatar
VegasBoy, check your piping for leaks (a leak check, not a visual inspection), and then find someone with a MAF you can swap on real quick.
jennz03
Lancer Troubleshooting
Feb 20, 2017 08:15 PM
emerica5571
AEM EMS
Oct 18, 2015 07:12 AM
xtasy
Jul 14, 2012 03:11 AM
evo unknown
Oct 31, 2009 05:25 PM
badhabit90
28
Aug 9, 2005 09:08 AM
