cosworth dyno on ix sean ivey
Old Aug 1, 2007 | 07:38 AM
  #166
High_PSI's Avatar
Originally Posted by BoOsTinGEVO190
If I throw my ams tbe would it change my A/F ?
Will i be ok to drive i know hks intake will me a differense im only going to put that a day before my tune
By a Mile. Your boost will also increase as well. Safe to drive? I suppose.. The car would adapt and probably add fuel all over the place. But since you are getting a tune it is ok.
Old Aug 3, 2007 | 04:50 AM
  #167
BoOsTinGEVO190's Avatar
it did exactly that
Old Aug 3, 2007 | 05:45 AM
  #168
Originally Posted by evolved83
any updates?
As for updates I spoke to sean there having problems with there neighbor complaining about dyno noise so I would have to wait a bit maybe road tune the car and just do 2-3 pulls on the dyno just make sure everything is running on point will see what happens
Old Aug 3, 2007 | 01:54 PM
  #169
4DR's Avatar
4DR
installed the ams tbe yestoday I do feel a little difference butt dyno is happy pm sean yestoday about scheduling a tune i only can do it sat hopefully his free soon for sat I'll throw my hks intake on day or two before my tune
Just keeping you guys updated
If you were already tuned "safely", then you should be fine. Think of it this way. I had a stock retune from vishnu. I added a catback/TESTPIPE/intake and I had no problems. You already had an exhuast, so switching to another shouldnt drastically changed anything. Go ahead, suck it up and bolt up the filter too.
Old Aug 3, 2007 | 02:27 PM
  #170
I'm not worried about that intake it takes 15min to swap intakes and that hks intake will change my a/f for 100%
Old Aug 4, 2007 | 09:06 AM
  #171
4DR's Avatar
4DR
I'm not disagreeing that it will change. IT probably should. But i doubt it will change enough to cause a "harmful situation"...i.e. going from a 11.2 afr to 11.9afr on a WOT pull....this i doubt. I guess the safest thing would be to leave it off since you will be getting a retune.
Old Aug 4, 2007 | 10:02 AM
  #172
BBS's Avatar
BBS
Sean surely did all he could with what you had, but unfortunately, he only had a few good mods to work with: the MBC and fuel pump. The rest of the mods are not so good, which is why you're making the power of an VIII with those mods. It's not like the car is slow, though. VIIIs would be very pleased with that much power on those mods.
I surely hope you aren't questioning the cams. Anything from cosworth is far superior than 90 percent of other products. It may not make the most whp but the R&D put into their stuff is no comparison to other companies.
http://jdm-insider.com/Blogs/Eric/
A good insight about why Cosworth pwns all.
Old Aug 13, 2007 | 08:50 AM
  #173
alright the tune should be on sat
Old Aug 13, 2007 | 04:18 PM
  #174
kouzman's Avatar
cool mate...
post before and after #s....
Old Aug 13, 2007 | 04:43 PM
  #175
Sean@Iveytune's Avatar
Yes he is coming in Sat to the Iveytune facility and will be using the NEW! AWD dynojet with 2 equal size rollers!!
Let's see if these parts make a difference.
Sean
Old Aug 18, 2007 | 10:58 AM
  #176
ok guys here it is 355whp 330tq
1st tune with these
mods
apexi intake --------------------------------------------- swap 1
rsr downpipe (catless) ---------------------------------\\
fujitsubo catback very quiet w/2 resonators-------// swap 2
cosworth cams
hallman mbc
fuel pump
80mph is 7k rpm just for someone whos not sure
NEW mods
HKS RS intake-------------------swap 1
AMS tbe w/resonator----------swap 2
AMS fmic--------------------------add
nisei licp--------------------------add
cosworth cams
hallman mbc
fuel pump
the graph is so nice thanks to sean ivey and his new shop
Old Aug 18, 2007 | 11:44 AM
  #177
Take that Apexi intake and fujitsobo catback lovers!! I told you that exhaust/intake combo sucks!!
Old Aug 18, 2007 | 11:46 AM
  #178
Sales@IveyTune's Avatar
HKS Racing Suction Kit FTW!
Kenny
Old Aug 18, 2007 | 11:58 AM
  #179
EVIL_EVO_VIII's Avatar
Finally made the numbers where u should be at.. Awesome Job Sean
Old Aug 18, 2007 | 02:37 PM
  #180
kouzman's Avatar
nice numbers mate!!!
Sean i dont think that the Apexi intake was the main reason for the power loss on the first setup... i would say that the VERY narrow fujitsubo exhaust made the numbers low... two resonators tapering to less than 2.5 inch doesnt make it a 3 inch exhaust as advertised...
the most amazing thing on the new setup is the around 30whp MORE at 7000rpm...
Congrats mate!!!!
