spark plug problem
Old May 21, 2007 | 11:29 PM
  #46
evilevo22's Avatar
i check for codes and its only cat codes now should i just take it to mitsu and have it fixed. How do you tell if the coil pack is shot. Could this be a bigger problem then just ignition. If anyone knows how i could fix this let me know cuz this is my dd
thanks
Old May 22, 2007 | 02:08 PM
  #47
evilevo22's Avatar
bump
Old May 25, 2007 | 12:55 AM
  #48
evilevo22's Avatar
how much could this cost at mitsu to be fixed will they work on a bolt on evo
Old May 27, 2007 | 02:23 PM
  #49
evilevo22's Avatar
How do you check if the coils are bad.
Old Jun 5, 2007 | 10:08 PM
  #50
evilevo22's Avatar
it ended up being the front o2 sensor. What is the best wideband that replaces the front o2.
Old Jun 5, 2007 | 10:30 PM
  #51
EvoTio's Avatar
That's an interesting outcome. How did you figure out it was the front O2 sensor?
Old Jun 8, 2007 | 12:24 AM
  #52
evilevo22's Avatar
i took it to mitsu. I know i didnt expect it tp be that. What widebands replace the front o2.
Old Jun 8, 2007 | 12:34 AM
  #53
moreryce's Avatar
well technically you have to have a front 02 sensor that connects to the ECU.. a wideband is a stand alone unit...
Old Jun 8, 2007 | 12:45 AM
  #54
evilevo22's Avatar
the dealership wants 700 for a stock one, and i needed a wideband which is also cheaper. Should i just get the bosch o2 sensor
Old Jul 22, 2007 | 06:04 PM
  #55
Falcon350z's Avatar
What was the outcome here? Did you get the O2 sensor replaced, and did it actually fix your problem?
Old Jul 22, 2007 | 06:12 PM
  #56
bluebyu36's Avatar
ya get the bosh,but i doubt thats the problem
Brent_si
Dec 1, 2011 01:47 PM
Countrystrong11
Sep 17, 2011 09:29 AM
polish_pounder
17
Jan 30, 2011 10:24 AM
Nismo2evoawd
Sep 18, 2010 11:40 PM
Derek888
13
Dec 9, 2005 12:26 PM
