FPRed turbo for Evo???
Old May 12, 2007 | 10:46 AM
Evo8Master's Avatar
Does anyone know if Forced Performance will come out with FPRed turbo for the Evo??? I know they made one for the subbie world with good results That would be nice. Just a thought
Old May 12, 2007 | 10:51 AM
4G63's Avatar
You are joking right?
There are prolly 50 posts about the 'Green'. Forced Performance website could help you out:http://store.forcedperformance.net/m...een=FPEvoGreen
Old May 12, 2007 | 10:59 AM
Azntoyhere's Avatar
I think he mean FP"red" not "green". But the Fp website could help ya answer some questions.
Old May 12, 2007 | 11:10 AM
Evo8Master's Avatar
What do you mean joking??? Read my post again... FPRED TURBO!!!! Not FPGREEN or 20GLT. I know about the green turbo already. Forced Performance has a red turbo for the wrx's and sti's
Old May 12, 2007 | 11:14 AM
Azntoyhere's Avatar
Yeah i read about the FPred it suppose to be the father of the Green turbo. Pretty nasty. But havent seen any EVO member mention about it. Must of not came out for it yet or they rather go with something else then that..
Old May 12, 2007 | 11:17 AM
Duby's Avatar
why bother? the FP3052 is a green(modified 50 trim) with dual BB senter cartige and some other mods while the 3065 is the same as a RED but more effiecent and powerful- in terms of DSMs where the 3065 for the evo is different then the 3065 for DSMs
If they made a 3052 or 3050 for the evo that might be wild but who knows. FP's green for the evo is just a moddified 20G/IX turbo frankenstein.
I had a Green and 50 trim on my 97gsx, not worth the price difference. Hopefully somthing comes out with a higher flow rating than 47-49psi 55+ but still with good spool up characteristics like the evo-green.
it there a way to make a 50trim spool faster ?
Old May 12, 2007 | 11:25 AM
vwjeff's Avatar
A red flows more than an LT. Buschur was selling one with a custom manifold for the Evo a while back . I would have bought it if I didnt already have there 35r kit
Old May 12, 2007 | 11:39 AM
Fast Frank's Avatar
A red would just be a green with a slightly larger compressor wheel-similar spool characteristics etc...around 52 lbs if it's like the subbie reds
Old May 12, 2007 | 11:44 AM
swordfish's Avatar
The Red that is available for the DSM used a 60-1 compressor paired with a TD06H turbine wheel. Robert would have to design a new compressor for a red for the evo like he did with the green. Our reverse rotation setup really screws things up as far as borrowing compressors and turbines from other turbos to fit our needs. Whereas with the STI and DSM you can just rob parts off garrett turbos and (no pun intended) Robert's your father's brother.
jeff
Old May 12, 2007 | 11:47 AM
4G63's Avatar
I'm sorry, I misread your post! I thought you meant "FPR'ed"!!!
Old May 12, 2007 | 11:51 AM
04WWRS's Avatar
As soon as sales start to slow down on the green, the red will come out. And be better. Thats been the formula ever since this 20g stuff started.
Old May 12, 2007 | 11:59 AM
mudduck's Avatar
From what I have heard, the FP Red was a 60-1 compressor based turbo that flowed a good bit more air than the Green, but had much worse spool-up - supposedly worse than a GT35r.
We need Robert at FP or someone to make a bolt-on turbo for the Evo that flows more than the Green and 50-trim (somewhere in the area of 55lbs/min or so), then make it dual BB for better spool-up as well as using either titanium blades or magnesium blades for the turbine wheel so it could spool even closer to stock and give some low-end torque.
I think if this ^^^ could be done, giving us the ultimate bolt-on street turbo, many of us would be willing to pay a little more for it...
Old May 12, 2007 | 12:15 PM
Exciting News's Avatar
Right up my alley. Doesn't seem to be a great variety of 'tweener' turbos out there. I'd give up a few 100 rpms on the green's spool for an extra 45-55whp/wtq.
Old May 12, 2007 | 01:34 PM
mchuang's Avatar
That is wrong, the FP3052 is not a modified 50 trim. According to an email i got from Robert at FP the FP3052 is a 3076 with a housing to suit the dsm manifold.
Old May 12, 2007 | 02:25 PM
scheides's Avatar
EvoM Moderator
FP3065 is about as close to a red as you'll get, but I think you'd have to purchase the kit through buschur.
