Any tricks for getting B-pipe nuts off at the stock cat??
Old May 16, 2007 | 10:45 PM
JDMevoBOOST's Avatar
Welp right now I am letting the WD40 settle in....but those nuts are on pretty tight....I have no air tools and am on my side trying to get it off. I can only imagine what a ***** this will be on the driver side......anyone got any tips????
This is most certainly not my first exhaust install....done plenty of hondas....but I really dont want to screw anything up ROFL
Old May 16, 2007 | 10:49 PM
thatguy's Avatar
Use a breaker bar if you have one.
They torqued the **** out of mine and it took some muscle.
I actually used a some metal pipe and pushed it threw the wrench handle so I could get better leverage.
good luck
Old May 16, 2007 | 11:11 PM
BBS's Avatar
BBS
^. Get a breaker bar AND a metal pipe to add some leverage. Dont use wd40 and get some liquid wrench or pb blaster. What also helps is to get the car warmed up. This gets the bolts nice and hot and are MUCh easier to remove. Plus the added heat will help the liquid wrench to soak through.
Old May 16, 2007 | 11:24 PM
ChuckP's Avatar
Could not have said it any better. Those bolts sucked. But get some Pb blaster, that stuff works better than wd40 imo.
Old May 16, 2007 | 11:32 PM
br built gsx's Avatar
bolts......
i used heat and the handle of my jack over the 3/8 rachet it worked great and of course did this on my back lol.
Old May 16, 2007 | 11:40 PM
newimportowner's Avatar
Jeepers guys just hit it with and impact so you dont snap them off
Old May 17, 2007 | 08:35 AM
Steve@NoLimitmotors's Avatar
torch
Old May 17, 2007 | 08:36 AM
DRFTKNGG's Avatar
Propane torch for a bit...then take the water hose and shock the nut with water..
Should come right off.
Old May 17, 2007 | 08:38 AM
DRFTKNGG's Avatar
You can snap a bolt off even faster with an impact. Not a good idea.
Old May 17, 2007 | 08:41 AM
Wolfb21's Avatar
i used a pipe over the end of a wrench also helps to use some pb blaster in there, and warming it up wouldnt hurt good luck let us know how it goes
Old May 17, 2007 | 09:35 AM
I actually got it off with just WD40 and my hand wrench....basically I got my feet on the mid pipe and pulled toward myself while pushing with my feet and they both came off....
Old May 18, 2007 | 09:02 AM
pog0's Avatar
I used an electric impact on mine and it came right now no problem.
GTisRule
Pacific Northwest
12
Jul 4, 2012 11:06 AM
saytheb
May 31, 2012 11:27 PM
Nesiop
Nov 20, 2011 11:36 AM
undercoverpope
20
Jul 20, 2011 10:54 AM
pjb00stin
Dec 24, 2008 05:22 PM
