How do i remove 02 sensor from 02 housing?
Old May 23, 2007 | 02:56 PM
JDMevoBOOST's Avatar
Kragen sells an o2 sensor socket it costs $15
Old May 23, 2007 | 09:01 PM
homiusang's Avatar
We spray the crap outta the sensor, use an open wrench and hitting with a hammer, while one guy standing on the exhaust manifold (turbo swap). Almost strip the damn sensor.
Old May 23, 2007 | 11:17 PM
ChuckP's Avatar
I ended up taking it to a local exhaust shop. The guy used a 02 sensor socket and broke it loose with a few swift hits to the ratchet. First "bolt" ive ever had to bow down to, hehe.
Old May 24, 2007 | 05:36 AM
TeStUdO's Avatar
Just goes to show that using the proper tools usually makes the job a lot easier.
Old May 24, 2007 | 06:25 AM
dudical26's Avatar
The 02 sensors seem to be cross threaded from the factory, at least mine was and so was several of my friends. This is why they can be such a pain to get out the first time.
Old May 24, 2007 | 06:54 AM
dsmfan95's Avatar
Torch and a 22mm wrench. Had to break mine loose yesterday.
Old May 24, 2007 | 06:59 AM
lexat20's Avatar
What is the cheapest place to buy a replacement?
Old May 24, 2007 | 07:08 AM
DRFTKNGG's Avatar
Worst case scenario.....get yourself a large pipe wrench.
Old May 24, 2007 | 07:12 AM
DRFTKNGG's Avatar
You can also try shocking it. Take a butane torch and heat up just the threaded part. Not so much you melt it. But it can take some heat. After you get it up to operating temps, take some water or a hose and spray it right on it. That usually works...
Old May 24, 2007 | 08:47 AM
Altr_Evo's Avatar
yeah try heating it up and use a line wrench
dinok
Sep 6, 2010 06:32 PM
03SilvaEvo
Jan 28, 2008 11:56 AM
one_fas_evo
27
Jan 1, 2007 08:37 AM
Jersey Dino
Dec 12, 2006 02:49 PM
mazdryk
AEM EMS
Apr 21, 2004 07:52 PM
