View Poll Results: Head studs yay or nay
Get them. Cheap safety net
116
59.18%
No need at this point. Keep the extra money
80
40.82%
Voters: 196. You may not vote on this poll
Honestly heads studs or not
Old Jun 10, 2007 | 08:48 PM
  #91
Evo8yurAMG's Avatar
Originally Posted by EVIL_EV0
I bet the fastest players didn't use the 1x1 method on their cars.
thats a true statement...lets hear from a 700whp + evo that did the 1x1
Old Jun 10, 2007 | 09:43 PM
  #92
Steiner's Avatar
Originally Posted by EFIxMR
I done the one by one method on both my EVO's and I have no leaks whatsoever.
It gives me the confidence to push my cars to 33 psi on my stock evo 9 turbo and 31 psi on my big trim GT30...
Without headstuds I personally would not push my cars that hard.
Thank you Andy!
Old Aug 21, 2007 | 08:42 AM
  #93
Sti THIS's Avatar
bringing back a dead thread. How bout an 05 with meth, stock turbo on 25-26 psi?
Old Aug 21, 2007 | 09:03 AM
  #94
MikSchultzy's Avatar
I'd still do them. Safety net reasoning.
And yes, I'm posting in an old thread:
I will be buying head studs while I have my engine torn down as well. However, I wouldn't buy studs just for the sake of buying them - I'd only really do the studs if you're going to be doing something else and have the engine down anyways. Otherwise, what's the point of putting studs in when you arn't doing anything to the engine anyways?
Old Aug 21, 2007 | 09:38 AM
  #95
Jeff_Jeske's Avatar
Waste of time and money. Opens the door for bad things.
The stock hardware is plenty good for a safe tune at 26psi.
Old Aug 21, 2007 | 10:14 AM
  #96
TTP Engineering's Avatar
Not needed. There are pump gas tuned IX's boosting those levels on 93.
Old Aug 21, 2007 | 10:55 AM
  #97
Sti THIS's Avatar
are the stock bolts different from VIII to IX
Old Aug 21, 2007 | 11:05 AM
  #98
Ted B's Avatar
Cylinder pressure is more or less a function of torque and load. A motor making 500 ft/lbs in 4th or 5th gear will test the fatigue limits head fasteners more thoroughly than anything.
The factory head bolts are probably like the factory rod bolts - less likely to be as reliable as the best aftermarket options, but reliable enough not to sweat it.
Personally speaking, I prefer studs to bolts everywhere they are applicable - primarily due to ease of service.
When installing head studs, I see no reason to physically remove the head. One can release one bolt at a time (starting from the outside), and replace each with the stud shaft so the head stays aligned. When all bolts have been removed and all studs are in place, the nuts can be torqued in proper sequence.
Old Aug 21, 2007 | 11:29 AM
  #99
C6C6CH3vo's Avatar
Replace torque to yield studs with ARP if you plan on detonating your engine constantly. If you dont plan on detonating and boost 12psi or 32 psi the cyl head pressure will be not much different and won't need ARP.
Don't get discouraged, this is just my opinion
Old Aug 21, 2007 | 11:36 AM
  #100
deadbeatrec's Avatar
Originally Posted by TTP Engineering
Don't get em!
dont need um!!! dont bother!!! dont waste ur moneys!!! dont listen to AL!!!
Old Jan 5, 2008 | 07:38 PM
  #101
SWOLN's Avatar
Is everyone pretty much still wishy-washy on the headstuds? Im getting some cams installed at the end of the month, so I'm on the fence. Right now, I'm thinking yes.
Old Jan 5, 2008 | 07:44 PM
  #102
housedj's Avatar
i say if ur gonna throw in cams, u might as well throw in the head studs especially in case u rev over 7800rpm due to a missed shift or something. + alot of ppl put cams in their car & don't do it right. if u buy cams don't forget the cam gears, springs, retainers, valve guides, stronger timing belt, & obviously the head studs & a retune...
Old Jan 5, 2008 | 07:52 PM
  #103
Steiner's Avatar
If I had to do it all over again I'd have installed head-studs AND these 3rd generation "non-ticking" lifters from Jackson Auto Machine. Do it right and you'll only have to do it once.
https://www.jacksonautomachine.com/h...fm?sectionId=2
Old Feb 4, 2008 | 10:32 PM
  #104
justin44's Avatar
im getting cams on my evo8 installed by Muellerized and he talked me into getting ARP headstuds. I am still at about 22 boost...
Old Feb 4, 2008 | 10:44 PM
  #105
C6C6CH3vo's Avatar
Headstuds and forged parts if you plan to push the engine into detonation or just want added protection for some reason. If the car isn't knocking no matter how hard your pushing it, and peak cyl pressure occurs when the piston is moving in the correct direction (down ) because it's timed and fueled right, then replacing the headstuds might actually create a problem
