Hallman Boost Controller Q&A...
Old Jun 3, 2007 | 10:48 AM
Ultimate CC's Avatar
I will try and help any questions related to hallman boost controllers from install to design...
Old Jun 3, 2007 | 11:16 AM
paymon's Avatar
is this the same one as the one sold on boostcontroller.com?
Old Jun 3, 2007 | 11:19 AM
IVERSON3270's Avatar
I have a crazy question......how do I know how many turns is 1 psi, I had my boost controller installed and its in cabin and its turn back to factory psi. And the word BOOST is unside down. So if I turn it one full turn back to where BOOST is unside down is that equal to 1 psi?
Old Jun 3, 2007 | 11:28 AM
tsi90awd's Avatar
A post listing the possible installation locations for the in-cabin controller would be really useful.
Old Jun 3, 2007 | 01:47 PM
lemmonhead's Avatar
can you explain this?
https://www.evolutionm.net/forums/sh...d.php?t=274733
Old Jun 3, 2007 | 01:53 PM
scottatyamaha's Avatar
Where is the best location for the mbc unit itself. I know you want it to be close to the boost source and wastegate, but if you had to choose one to be closer to what would it be. Also I heard it is good to keep the unit close to heat, so that is why i mounted mine on my valvecover. What do you think?
Old Jun 3, 2007 | 03:44 PM
hallmanboostcontroller.com, I also happen to sell them hence why I started a thread to answer the questions for em......
Old Jun 3, 2007 | 03:46 PM
every car and turbo setup is a little different so theres no set amount of turns...
Old Jun 3, 2007 | 03:47 PM
we could do that right in this thread if you want...
Old Jun 3, 2007 | 03:48 PM
Originally Posted by lemmonhead
posted...
Old Jun 3, 2007 | 03:50 PM
just about anywhere on the car will work for a mbc but the general rule of thumb is as close as you can get to the boost source itself...on the evo it works well on the valvecover...
Old Jun 3, 2007 | 04:01 PM
alby988's Avatar
dan, what comes with the mbc? does it come with the hosing and such
Old Jun 3, 2007 | 04:03 PM
it comes with the controller, a hose, two springs, a bracket and some misc hardware...
Old Jun 3, 2007 | 04:07 PM
Thegame's Avatar
I do beleive that on most stock turbo cars, seven turns (+/- .5 turns) is right around 21.5 psi (+/- .5 psi.) On the stiff spring that is. During my road tune, Al knew exactly where to put it and after one setting, he was right on.
Old Jun 3, 2007 | 05:39 PM
lemmonhead's Avatar
