Trouble shifting @ high rpms
Old Jul 8, 2007 | 11:23 AM
Jean's Avatar
Originally Posted by Evoryder
WHERE YOU GETTING THE MOUNTS FROM? how much is labor?
Well i already have them ( dont remember what i paid) and ill prob do it myself or at Fynetune so not sure what labor will be if any.
If you want ill try to find out for you.
Old Jul 8, 2007 | 11:27 AM
Jean's Avatar
Originally Posted by dxbevo9
yes..i researched about this all over the place..i am experiencing exactling the same things you described except with a different clutch...
the best solution for this now is a stiffer engine mount and torque dampner...
however...a better solution is going with the RalliArt HD lightweight clutch..
I didnt think it was the clutch, since i had it without that issue.
I was hoping it was the mounts which i am going to change since im guess my engine and tranny just move too much. At the moment thats the only thing i can think of that would cause the issue.
So has the problem gone away for you with the upgraded monts?
Old Jul 8, 2007 | 11:32 AM
Toobs's Avatar
Had the same problem, motor mounts fixed it.
I did the 2 side mounts and the front.
Hope this helps...
Old Jul 8, 2007 | 11:34 AM
Jean's Avatar
Hope this helps...
Thanks.
Old Jul 8, 2007 | 11:46 AM
dxbevo9's Avatar
i havent installed the mounts either...i am waiting for the weather to cool down a little..
let us know if your mounts fixed the problem.
Old Jul 8, 2007 | 11:55 AM
nos51's Avatar
I drove the exedy clutch on shreks car a couple times and it felt different. Like alot softer.
I figured it was because of the hydraulic release bearing that caused the pedal to be so springy, more like an off and on switch compared to other clutches.
It grabs a hell of a lot harder when going through the gears. Even when just cruising. So i started driving it different when going through the gears.
Not to mention the noise that it makes when starting into first gear. The chatter isnt so bad tho.
I cant be heard at drive throughs when i drive the EVO i am always told to drive up to the first window and my order will be taken there. hahaha. squeeeee squoooooo aghhhhhhh then theres the exhaust.
But i had the tilton with a stock motor and a reflash and i didnt have that problem. So i was hoping maybe i just have too much engine movement or something that i can fix while its down.
I hope to have it fixed by my b-day in August. Then go look for all the big boys in Mia.
whats weird is that my brother in laws tilton ceramic is no where near as loud as yours.its quieter than my exedy.i was expecting it to be as loud as yours.
Old Jul 8, 2007 | 11:57 AM
Jean's Avatar
How long has he had it installed?
If its still pretty new under ~600 miles it will get louder.
Old Jul 8, 2007 | 12:11 PM
Evoryder's Avatar
i'LL probably get the mounts from TTP, i could probably install myself...I did my clutch myself...
Old Jul 8, 2007 | 04:08 PM
Jean's Avatar
Cool. Nothing beats free labor.
Old Jul 9, 2007 | 05:04 AM
TTP Engineering's Avatar
Your clutch is likely being overstroked. You should be using a TILTON PEDAL STOP for this reason as it will limit the travel of the hydraulic release bearing. When overstroked it tries to re-engage the clutch again.
Old Jul 9, 2007 | 05:24 AM
dxbevo9's Avatar
TTP..
how do i eliminate this over stroke problem?
Old Jul 9, 2007 | 06:12 AM
dudical26's Avatar
TTP..
Do you have a tilton clutch?
You said you have the same problem but with a different clutch. I would imagine over stroke is only a problem on push type clutches.
Old Jul 9, 2007 | 06:30 AM
Jean's Avatar
TTP: ill check that also but i didnt have that problem before.
Thanks.
CaptainSquirts
May 17, 2016 08:35 PM
Sieu Toc
Mar 27, 2014 05:10 PM
rupp003
33
Aug 29, 2013 10:26 AM
C6C6CH3vo
19
Jul 18, 2011 08:22 AM
def1
11
Oct 26, 2008 01:18 PM
