Boost guage and turbo timer install price?
Old Jun 27, 2003 | 09:06 AM
XRS-Lift's Avatar
Hey guys. I want to get a greddy turbo timer and a boost guage installed but i dont want to mess anything up. Im new to turbos. How much do you think the installation should cost for both of those and the time it should take for each installation? Thanks.
Old Jun 27, 2003 | 12:06 PM
wojo's Avatar
First of all, let me say that I would suggest installing it yourself. It might be a bit time consuming and annyoing, but you will achieve the following:
1. Save a lot of cash (see below)
2. Learn how it is hooked up and how it works, so when something goes wrong you can easily diagnose it
Most shops will charge you per hour. They will probably figure 1-2 hrs for the TT depending whether it has any extra function. They will probably figure the same time for the boost gauge, although there should be some time savings if you're installing it at the same time, so maybe an extra 45-60 minutes for the gauge.
So you are probably looking at 2-3 hrs of mechanics time at $60-80 per hour, which would run you $120-240. I have seen people pay that. Again, I would suggest doing it yourself.
Old Jun 27, 2003 | 12:11 PM
nastea's Avatar
its not that hard, many other folks have written up faq's with pictures step by step on how to perform these two functions. these two i would consider very very simple additions
Old Jun 27, 2003 | 12:51 PM
bs's Avatar
bs
yeah i agree. if you can read instructions then you can install these items with ease. these are actually good places to start for first installs imo. the defi boost gauge in my evo was the first thing i had ever installed and it was very easy! don't pay $200 to get these installed.
Old Jun 27, 2003 | 03:06 PM
BadBoyBeltran's Avatar
Yeah. I'm sure you can do them, yourself. Some TTs even come with a harness that is a direct bolt on to the harness under your steering column. Pretty easy stuff.
Old Jun 28, 2003 | 02:22 PM
CVL EVO's Avatar
I heard that installing a boost gauge will void the warranty, Is this true?
Old Jun 28, 2003 | 05:22 PM
XRS-Lift's Avatar
very cool guys, i wasnt sure how difficult it would be to install these items. the guy at my shop said 175 for the turbo timer install i think including a greddy tt. I think he said it would take about 5 hrs for the TT install or maybe he was talking about both installs, but either way that doesnt sound right.
Old Jun 28, 2003 | 09:39 PM
__NiTe__'s Avatar
$175 is a rip off for just the turbo timer install. You can just do it yourself. It takes about 3-4 hours and isn't that much work at all. It's not worth that much money. Maybe both installs together... But not the TT by itself.
__NiTe__
Old Jun 28, 2003 | 10:12 PM
evolife04's Avatar
if you want some help i can do it for you just hit me up i installed is2000 greddy guage for him you can watch and learn for the next install and you can try it your self then... im in SOCAL also
Old Jul 7, 2003 | 09:28 PM
keviin's Avatar
my god.. it costs that much to install a tt... that was the most simple thing i've done... easier than rotating my wheels! i think it took me about 10-15 minutes total time! however i did have a harness...
Old Jul 8, 2003 | 06:01 AM
silverEVO8's Avatar
It depends on what you consider "easy" and whether one has the tools, space and time.... For instance, just running the wires and lines from the engine bay to the inside of the car can be a tedious and difficult job in the EVO. Running the wires for my HU was quite a job and required removing the fender liner, etc.
Mounting the gauges can also require a lot of thought and some good skills plus a good supply of miscellaneous odss and ends... For me, a top notch, quality installation is worth the money I pay to get it done... OTOH, a hack job done by some incompetent fool is worse than anything I can butcher up myself. Personally, I don't have much time or a place to do these things, so.....
TREVORSEVOVIII
Jan 6, 2008 10:07 AM
crasher
Jan 31, 2007 07:50 AM
ak47po
Sep 12, 2006 07:04 PM
TheOnlyDC5
Jan 29, 2006 11:36 AM
jesterEVO
Automotosports - Illinois
Dec 7, 2004 09:02 AM
