a/c noise
Old Jul 19, 2007 | 11:14 AM
gen3eclipsegt's Avatar
Question a/c noise
when i idol with the a/c on i have clutch chatter noise is that normal??? i dont know what kind of clutch i have i do know its aftermarket from wehn i bought the car i was told its a twin disc clutch and lightend flywheel... but should it be chattering at idol ... when i push the clutch in it goes away
Old Jul 19, 2007 | 11:19 AM
Spookpur's Avatar
You're sure it's the clutch rattling? Maybe the A/C compressor bearing?
Old Jul 19, 2007 | 11:38 AM
Muad's Avatar
I'm sure it's fine, mine does the same thing with my stock clutch. Your idle will drop as well, which seems to makes it even louder
Old Jul 19, 2007 | 11:41 AM
silver evo8's Avatar
whenever i put my air on my steering wheel vibrates and my car drives totally different but this is normal
Old Jul 19, 2007 | 11:46 AM
alrite sounds good haha thanks i just havnt used the ac i didnt know if that noise was normal .... yeah i think it is comming from the clutch beacusae when i push the cluch in the noise will go away, its a loud clutch especially when i declerate in speed i hate it
Old Jul 19, 2007 | 11:47 AM
VtexGt3's Avatar
same here. Its the clutch because if you depress the pedal the noise will diminish significantly. AC eats a lot of power from your car, when it's on, you'll feel like you're driving a geo metro..
Old Jul 19, 2007 | 11:48 AM
not much a geo metro it goes from a evo to a oz ralley with a whooshing noise when i shift haha
Old Jul 19, 2007 | 11:49 AM
VtexGt3's Avatar
hahaha yea, the A/C button actually turns off the turbo and has it blow air at you instead of the engine. haha
Old Jul 19, 2007 | 11:51 AM
so is that normal as well for a twin disc to be that loud especially when slowing down ... and is it bad to let the clutch chatter like that
Old Jul 19, 2007 | 11:56 AM
VtexGt3's Avatar
well when evos idle you get a good amount of vibrations through the body of the car, and just as how your steering wheel shakes so will the clutch. Can't really do too much to avoid that. you can prob get some dampeners if you REALLY wanted to. As long as the clutch was installed properly i don't see it being a problem... but i guess that brings up the question of the installation...
Old Jul 19, 2007 | 12:00 PM
well it shifts fine and seems like a great clutch just extremelly grabby i can get used to that just slowing down coasting or with the ac on i hate the thing but having it do that noise it wont hurt the cltuch or flywheel chattering? as long as it wont do any damage to the clutch i dont mind just crank the radio up more , if it dose more reason to get a new clutch haha
Old Jul 19, 2007 | 12:01 PM
fastrob691's Avatar
Probably not even the clutch my AC has always been loud, and its a different noise than the twin disc, theyre loud but different, my a/c made noise with the stock clutch, stock exhaust, stock everything
Old Jul 19, 2007 | 12:03 PM
my-red-rs's Avatar
I have a stock clutch on an EVO that has low miles, and I have the exact same noise (only at ide with A/C on).
If I depress the clutch, rev the motor, or turn off the A/C, the noise goes away.
Old Jul 19, 2007 | 12:05 PM
im glad my fellow evo owners have the same nosie welcome to the world of dsm ac i guess thanks for all your help guys appericate it
kenshi3
Apr 2, 2011 01:28 PM
chasethorpe5126
16
Mar 31, 2011 10:03 AM
boostedawd
33
Jul 5, 2009 08:52 AM
zacmck3
Lancer Engine Tech
Apr 30, 2009 11:03 AM
gen3eclipsegt
Apr 6, 2007 10:27 PM
