Dyno#s with Cosworth cams and camgear settings!!
Old Jul 21, 2007 | 07:42 PM
  #46
Ludikraut's Avatar
What's with the mailto link?
l8r)
Old Jul 22, 2007 | 06:06 AM
  #47
Ted B's Avatar
Originally Posted by Turbo Kyle
Whats the most you can advance/retard the intake cam with the mivec?
AFAIK, MIVEC does not retard.
I might toss in that the Cosworth IX intake cam may not be the same specs as the VIII if they took this into consideration. There's just not enough information here to resolve the most obvious questions.
Old Jul 22, 2007 | 06:34 AM
  #48
gkania's Avatar
Miguel had the spec sheet, he should be able to post them up. I believe its 11.2 lift and 111 was the separation. It was two weeks ago I saw the sheet though so that's probrably way off
Old Jul 22, 2007 | 08:08 AM
  #49
EVIL_EVO_VIII's Avatar
The lift is 11.0mm
Old Jul 22, 2007 | 03:17 PM
  #50
Turbo Kyle's Avatar
So MIVEC only andvances?
Old Jul 22, 2007 | 04:22 PM
  #51
I believe MIVEC both retards and advances the timing
Old Jul 23, 2007 | 07:41 AM
  #52
Ted B's Avatar
That's not what I recall, so you may want to check into it.
Old Jul 23, 2007 | 01:16 PM
  #53
Soon2BEVO's Avatar
Are you going to the track or what?
Old Jul 23, 2007 | 02:51 PM
  #54
Whoop_ass's Avatar
^ +1 then you backup your power figures
Old Jul 23, 2007 | 03:02 PM
  #55
TTP Engineering's Avatar
He's been to the track and burned up the clutch from the 1,024ft-lbs all wheel torque.
To be continued.
Old Jul 24, 2007 | 08:45 AM
  #56
Warrtalon's Avatar
Didn't do well at the track then?
Old Jul 24, 2007 | 08:47 AM
  #57
2.2+ 60' launches and having to let off a few times due to clutch slip.
Old Jul 24, 2007 | 08:52 AM
  #58
Soon2BEVO's Avatar
Stock clucth sucks.
Old Jul 24, 2007 | 09:21 AM
  #59
12.8@ 111.6 with the clutch slipping, i had to let off twice in first gear and roll it bc it slipped so bad, 2.2 60ft, and i was hitting the rev limiter before crossing the 1/4 at 7800 and 90 degree weather to top it off. Will be getting a new clutch installed within the next 2 weeks and ill be back at the track soon
Old Jul 24, 2007 | 10:01 AM
  #60
Viciouslord's Avatar
Originally Posted by EVIL_EVO_VIII
Well as i promised.. Went to CFT today and dynoed the car.. This is a MUSTANG DYNO... It reads 5-6% lower than a dynojet. Cars that have dynoed what i made have trapped 118-119...It was 102 DEGREES in the dyno bay!!!! Mods are in my sig and this was on 93 oct.. There was NO Ecu tuning on the dyno, this is how it was tuned on the street
First run the car made 332.3whp and 333.1wtq@ 24.xx psi spike with a -4 degree timing on the exhaust cam gear
Second run the car made 326.2whp and 333.5wtq@24.xx psi spike also at -4 degree cam gear setting.
Third run the car made 342.1whp and 351.2wtq@24.xx psi spike at -2 degree cam gear setting. Looks like this made a BIG difference!!
Fourth run the car made 340.7whp and 346.3wtq@24.xx psi spike also at -2 degree cam setting and i just left it at that..
I will post dyno sheets tomorrow guys..Im very happy with the results on pump gas. The guys at CFT were very impressed with the car. Last week i ran a Evo VIII that trapped 116 and i pulled 3 cars on him..
FYI... for Fidanza cam gears, 1 mark means 1 degree of timing.... TTP set yours at -2 degrees Ex.
so actually your 1st and 2nd run were at -2 Ex.
the 3rd and 4th run were at -1 Ex.
but overall nice numbers
