my buschur turbo kit bolts keep on backing out!!!!!!
Old Jul 23, 2007, 12:33 PM
  #31
jbfoco's Avatar
You can drill into the manifold, pin the studs in to the manifold. Use castle nuts with a saftey pin. If its done correctly it will not fail.
Old Jul 23, 2007, 03:41 PM
  #32
MrEvo2U's Avatar
BR probably can sell you studs (they shipped mine with studs). Install the studs into the turbo first and tighten them (you'll have to double nut). Install the turbo from the bottom and use metal lock nuts (all of this was shipped with my BR 3065 kit). I re-torqued after a couple heat cycles and no problems.
Attached Thumbnails my buschur turbo kit bolts keep on backing out!!!!!!-evo.jpg
Old Jul 23, 2007, 11:00 PM
  #33
jbfoco's Avatar
lock washer suggestion....
worthless the heat will flatten it out.
Old Jul 24, 2007, 01:44 AM
  #34
ant_turbo's Avatar
There's a place here near me in (COVINA) Called KING BOLT and they have everything!!!....
4680 N Grand Ave
Covina, CA 91724
(626) 339-8400
Originally Posted by riceball777
where can i get studs>?????
Old Jul 24, 2007, 10:10 AM
  #35
DSMu4ia's Avatar
You must make sure that you are torquing "hot side" bolts/nuts/studs when the car is at operating temperature. This will make a huge difference.
If you want the best lock washers out, look no further than NORDLOCK
http://www.nord-lock.com/
riceball777
Nov 23, 2016 09:41 PM
riceball777
Nov 8, 2016 02:23 AM
riceball777
Aug 25, 2013 04:03 AM
riceball777
82
Apr 8, 2013 01:44 AM
riceball777
Sep 25, 2012 01:30 AM
Quick Reply: my buschur turbo kit bolts keep on backing out!!!!!!
