Code P0300
Old Aug 4, 2007 | 05:53 AM
DESERTEAGLE50's Avatar
Code P0300
I went to the track for the first time last night and on my second run my check engine light came on. I had it checked and P0300 is the code that's coming up and it's for random multiple cylinder misfires. Any ideas on what would cause this?
Old Aug 4, 2007 | 06:01 AM
tehforbes's Avatar
i have had that code pop up a couple of times after i had some cams installed. do you have aftermarket cams?
Old Aug 4, 2007 | 06:40 AM
PurEvo's Avatar
Same thing happen to me once. check your egr vacuum line. I might have popped off. I dunno if it's related but mine popped off and when I put it back on, the light went away.
Old Aug 4, 2007 | 06:42 AM
Turbo Meg's Avatar
Bad gas??
Old Aug 4, 2007 | 06:50 AM
El.BlueEvo9's Avatar
There is a little tube under your intake manifold. Feel around under there because it probly came off. It came off due to high boost.......zippe tie it................Atleast I think it was the 300 code........
Old Aug 4, 2007 | 06:53 AM
scottatyamaha's Avatar
P0300 code is for mutiple random cyclinder misfire. It can be a real or false code. Things that can fasly trigger it are loppy cams or too much timing at idle from a recent tune or ecu flash. If the light only comes on when the car is idling more than likley you do not have misfire, but if the light comes on when you are accelerating or driving you could really have a misfire which could be bad. Things to check...plugs and plug wires.
Old Aug 4, 2007 | 06:54 AM
^^Nope, sorry, I think I was thinking of a deffrent code.
Old Aug 4, 2007 | 06:58 AM
Ya your right. This happend to me in the past when my idle would dropped to low. But it's fixed now
Old Aug 4, 2007 | 07:02 AM
No my cams are stock.
Old Aug 4, 2007 | 07:32 AM
What about any thing else I said?
Old Aug 4, 2007 | 02:53 PM
Luis@TTP's Avatar
deffinetly check your spark plugs and for a vacum hose bieng off. it can lean out the idle and cause it to throw this code also.
Old Aug 4, 2007 | 03:00 PM
SiCKlEyWiKeD's Avatar
+1, also, not to sound like a d1ck but do a search. They're a lot of threads on this code because it is pretty common.
Old Aug 4, 2007 | 04:39 PM
you do
Old Aug 4, 2007 | 05:01 PM
bolvangar's Avatar
P0300: Random/Multiple Cylinder misfire detected.
-Refer to P0201 - P0204 - Injector Circuit Malfunction.
DJErickG
Feb 11, 2015 05:57 PM
dxlykos0131
May 7, 2014 06:15 AM
8-BallEvo
Aug 3, 2010 07:55 PM
afmafia
15
Aug 22, 2008 06:29 PM
tequila083
Apr 6, 2006 11:30 AM
